I am getting ready to install boost, water temp and oil pressure. I have the boost and water temp senders taken care of and I am still working on the sender for the oil pressure. My questions is, were did you tap the power from? Are there any fuse block spots that have running power that you have found? I would prefer to have a separate circuit just for the gauges. Thanks
