Interior/Exterior headlight rings
Old Jan 6, 2009 | 08:45 PM
overheadcam11's Avatar
overheadcam11
headlight rings
Does anyone have any good detailed instructions on painting the headlight rings?
Old Jan 6, 2009 | 09:00 PM
Malcon's Avatar
Malcon
I think somebody did a write up somewhere??
try a search??
Old Jan 6, 2009 | 09:10 PM
4Boogie's Avatar
4Boogie
all throttle no bottle
-unhook neg. battery cable
-unhook bulbs and headlight washers if Xenon
-remove 2 screws in leveling motors so you can get to the bottom nut
-10mm socket to remove 3 nuts
-place sheet over engine so you dont lose nuts first
-you should have headlight out at this point. pull washer motor out to remove half moon shaped metal piece first. be careful I broke my first one . then you can pry the rest of the ring off
Old Jan 6, 2009 | 09:45 PM
MUShadd's Avatar
MUShadd
leveling motors? do you mean the ballasts?
Old Jan 7, 2009 | 06:08 AM
Jahmills's Avatar
Jahmills
This thread has pretty good instructions starting on pg 2. That is what I used last summer.
https://www.northamericanmotoring.co...s-or-no-2.html
Pic from a couple of weeks ago, more than 10k miles and no rock chips.
Old Jan 8, 2009 | 07:19 PM
SHOCKER's Avatar
SHOCKER
does anyone on here know if the 07/08 headlights tht everyone seems to be doing the joey mod on will fit into an '02 cooper non s?
Old Jan 8, 2009 | 10:22 PM
MUShadd's Avatar
MUShadd
no, but u can get 05 -06 lights, theyre different than pre 2004 lights and easy to joey mod (like i did)
elverado
Jan 18, 2022 02:51 AM
bahman
Aug 6, 2016 07:19 AM
j_parker
Nov 8, 2015 04:54 PM
Burkee52
Electrical
Sep 18, 2015 11:12 AM
tylewis
Sep 6, 2015 07:36 PM
