Interior/Exterior Alta guages
Old Dec 29, 2008 | 06:21 PM
ANT818's Avatar
ANT818
Alta guages
Alta water temp and boost guages successfully installed. I can't figure out why the guages are not always on. It seems when the automatic headlights are on, the guages will only work if the headlights are on. If you switch the lights to the on position the guages work. Any suggestions to make the guages work all the time?
Old Dec 29, 2008 | 06:24 PM
iwashmycar's Avatar
iwashmycar
sounds like you miss-connected a wire... check the directions for the orange and white wires. did you tap the right one in the console?
Old Dec 29, 2008 | 06:37 PM
scott48's Avatar
scott48
you mean they don't go on when you start your car up?
Old Dec 30, 2008 | 06:07 PM
schatzy62's Avatar
schatzy62
Sounds like you connected to the wrong wire.
Old Jan 3, 2009 | 12:00 PM
Red Bull's Avatar
Red Bull
How about some pictures??
Old Jan 3, 2009 | 02:26 PM
JAceMin's Avatar
JAceMin
The automatic headlights are not part of the switched light circuit, so if you tapped that as your source of power you will only get power when you switch on the circuit. Odd logic, but for some reason the ECU does not power up the circuit when in Auto mode.
This thread has a good reference for switched power, and constant power, I used to wire in my gauges.
https://www.northamericanmotoring.co...not-fuses.html
Old Jan 7, 2009 | 11:34 AM
ANT818's Avatar
ANT818
that's funny. the gauges power up in auto position but don't off position.
Debi's Coop S
Dec 27, 2015 02:35 PM
vulkandino
Oct 31, 2015 08:29 PM
Joeygonz
Oct 4, 2015 09:25 PM
Debi's Coop S
Oct 3, 2015 07:49 AM
gnhovis
Sep 28, 2015 06:28 AM
