Interior/Exterior Need DIY for removing interior peices.
Old Oct 20, 2008 | 01:19 AM
MrCooperS's Avatar
MrCooperS
Moderator
I've tried the search function and only found the way to remove the 3 piece plastic trims. (Start with the removing the tach, and it's pretty much yank and pull)
I'm doing this because I'm getting ready to paint the interior pieces to another color. I was wondering if there is a DIY (which I can't find) on removing the 2 pillar pieces of the center console and the plastic door pieces. Thanks.
Old Oct 20, 2008 | 04:41 AM
chris.j.lamb's Avatar
chris.j.lamb
The 2 pillar pieces come off after the dash parts by removing the 2 screws in each side and then sliding them up/down and out.
The door plastic parts are NOT removable, they are heat welded to the main door moulding, perhaps you could mask and paint.
Old Oct 20, 2008 | 10:02 AM
MrCooperS's Avatar
MrCooperS
Moderator
cool thanks.
Old Oct 20, 2008 | 10:14 AM
AutoXCooper.com's Avatar
AutoXCooper.com
[quote=itsminidrmer;2516884]I've tried the search function and only found the way to remove the 3 piece plastic trims. (Start with the removing the tach, and it's pretty much yank and pull) [quote]
the tach is not yank and pull. Lower the steering wheel all the way down, there's two bolts that hold the tach to the steering column, when you remove the tach you will need to unplug it too. Once it's off, there's screws on the back to remove and this will allow you to take it all apart for painting.
Old Oct 20, 2008 | 10:48 AM
chaseabryant's Avatar
chaseabryant
It could depend on how much time and work that he wants to put into it... I removed and painted my door trim, other than the y-shaped handle, by going behind and drilling out all of the plastic rivets. I then re-attached with silicone. A lot of time, however, I do believe that I got a much more even paint job, and didn't have to deal with all of that taping.
-Chase
Old Oct 20, 2008 | 02:20 PM
second to none's Avatar
second to none
When removing the tach (unplugging), make sure the KEY is OFF! or else your lights stop working, and your odometer stops counting miles
Kimolaoha
Jul 5, 2023 01:04 PM
Sailorlite
Sep 21, 2015 12:00 PM
greekzilla
Aug 23, 2015 03:44 PM
xraycat
Aug 12, 2015 02:36 PM
