Interior/Exterior Rear Back Up Light Install
Old Aug 15, 2003 | 06:15 AM
CoopingInDC's Avatar
CoopingInDC
Hello!
I'm looking to install a rear lucas lamp, on an external switch, to use as a back up light. For me, this is all very simple, BUT, I do not know where to mount the lamp!
Any ideas/suggestions/pictures on where i can mount the single lamp on the back end?
thanks so much!
Danny
Old Aug 16, 2003 | 06:12 PM
Minimad's Avatar
Minimad
I'd be inclined to make a steel bracket that would attach & come out from under (or the side of) the tailgate....???? Thus making no holes in the body. Therenot much to do with the plastic bumper cover, but on the right side, where you see a semi-circular plug the aluminum impact beam has a higher area that you may be able to screw thru the cover & into if your inclined. Pull the cover off before venturing into anything.
Mini'mon
Aug 26, 2015 01:02 PM
Minibeagle
Aug 13, 2015 10:00 AM
Aug 7, 2015 05:56 AM
