Interior/Exterior Can I swap out auto AC with manual AC??? Can I replace stand
Old Aug 6, 2003 | 08:25 PM
200mph's Avatar
200mph
Help please:
I want to swap the auto AC in one MINI with the manual AC in another. What needs to be changed besides the under-dash control unit? Is the auto AC temp sensor in the front of the headliner? Is there another sensor in the rear? Are the wiring harnesses in both cars the same??
Similar question:
I want to upgrade the sound in one Mini to the Harmon-Kardon option spec. In addition to the HK amp and speakers, does the head unit need to be swapped also? And again, are the sound system wiring harnesses in both cars going to be the same?
I know it sounds like lots of work, but without waiting months for a car built to spec I couldnt be too choosy about options. Now I'm trying to make mine like I would have ordered it.
Thanks in advance,
Mike
Old Aug 6, 2003 | 08:32 PM
TheBluePotato's Avatar
TheBluePotato
Mike - you may want to re-post this in the AUDIO section as well as UNDER THE HOOD. More appropriate for those forums and may get more responses. Let me know if you would like me to move the thread.
-Peter/Moderator
Old Aug 8, 2003 | 08:21 AM
200mph's Avatar
200mph
The MINI master tech at the local dealer showed me why trying to replace the standard AC with climate control AC is a fool's errand. There is way too much to be changed to make such a swap worthwhile.
The HK question is now posted in the audio form.
Thanks for the responses and advice.
Mike
Old Aug 8, 2003 | 08:25 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
The short answer for the stock radio to HK swap is nope for anyone that doesn't have the HK wiring harness preinstalled.
danielbrookes_9
Oct 3, 2015 12:51 PM
Bennyboy
Aug 18, 2015 07:28 AM
Powershift
Aug 16, 2015 05:14 PM
minipopkart
Aug 13, 2015 05:22 AM
