Interior/Exterior Any DIY's for black-out door handles, light rings, gas caps?
Old Mar 3, 2009 | 11:14 AM
  #376
call it spade's Avatar
call it spade
pics blimey? :D
Old Mar 12, 2009 | 11:37 AM
  #377
Handsome Rob's Avatar
Handsome Rob
I finally made a stop at my local Home Depot and picked up 2 cans of Plasti Dip. I sprayed the fuel cap, both door handles and hood scoop all in one night. It really didnt take that long to do. I will try to post some pics soon.
I think they all turned out really good.
This weekend I am going to tackle the headlight rings and the front grille chrome pieces. Hopefully those will be easy. We shall see.
Old Mar 12, 2009 | 01:32 PM
  #378
skillet's Avatar
skillet
Headlights are easy. Just take your time and look things over.
Old Mar 13, 2009 | 07:35 AM
  #379
coopercabra's Avatar
coopercabra
If you take an exacto knife to the adhesive at the bottom of the headlight ring they come off real easy, you have to pry at one side first then once you have enough space run the exacto through the adhesive tape there should be about 4 pieces of tape so take your time the clips are pretty easy to break.
Old Mar 13, 2009 | 07:43 AM
  #380
BlimeyCabrio's Avatar
BlimeyCabrio
^ exactly the way I do it.
Old Mar 13, 2009 | 02:00 PM
  #381
Handsome Rob
How hard is it to do the headlight rings without actually removing the headlights? I did the hood scoop without removing it and that was pretty easy. I just dont want to break anything during removal or reinstallation.
Old Mar 13, 2009 | 02:28 PM
  #382
MUShadd's Avatar
MUShadd
its possible, but you will likely break a tab or two. you can always just tape them back on if you break too many tabs. they are also taped on from factory too.
honestly, 3 bolts and unplugging ur washers is all there is to removing the headlamp. its much easier to do it that way.
Old Mar 13, 2009 | 02:45 PM
  #383
Handsome Rob
I can partially remove the headlight. I didnt have a whole lot of time to mess around with it, but where on the washers do I need to disconnect it?
I should have more time this weekend to figure it out.
Old Mar 14, 2009 | 12:12 PM
  #384
skillet's Avatar
skillet
I believe there was a plastic clip of some sort that connected the hose to the headlight washer. You're gonna have to play around with it as I don't remember what I did to get it off...squeeze, pull, curse, etc...
Old Mar 14, 2009 | 01:45 PM
  #385
Duck360198's Avatar
Duck360198
what would people recommend to get the side markers body colored?? Paint won't stick to the chrome right? How do you sand something so small like that? I want it match the dark silver metallic as much as possible. Any insight would be great.
Old Mar 14, 2009 | 02:16 PM
  #386
BlimeyCabrio
A couple of options:
1) start with the Cooper vents. They're not chrome
2) Sandblast the Cooper S vents before painting.
3) Sand the Cooper S vents. It's doable... just tedious to get in all the nooks and crannies (you need to disassemble them first).
Old Mar 14, 2009 | 03:18 PM
  #387
call it spade
Back in the day when i was a super NOOB at painting i just taped cleaned and sprayed. to this day the paint is on the side markers un-chipped but. it is not a proud day in my life. haha
Old Mar 14, 2009 | 04:35 PM
  #388
Duck360198's Avatar
Duck360198
Would the Cooper grilles need to be sanded??? A bodyshop guy said the S grilles would get destroyed if they were sandblasted. Is that true??
Old Mar 14, 2009 | 06:19 PM
  #389
MUShadd's Avatar
MUShadd
trace the hose from the headlight, you;ll come to a plastic elbow. youll see the clip there...
the chrome will be destroyed. only way u destroy the grills would be to crank it up and blast the plastic away.
Old Mar 15, 2009 | 08:03 AM
  #390
BlimeyCabrio
Yeah, I'm not talking about a lot of blasting. You don't need to get *all* the chrome off... just roughen the surface enough for primer to stick well...
Old May 9, 2009 | 11:34 AM
  #391
wukusick's Avatar
wukusick
I read a lot on here about plasti-dipping the gas cap, door handles, etc...but has anyone tried doing this on the chrome mirror caps? I want to get the black ones, but buying from the dealer and having them painted sounds expensive. I guess I could give it a shot, if it doesn't work I can peel it back off right?
Old May 9, 2009 | 05:43 PM
  #392
call it spade
Yes, you can do it on the chrome mirror caps (same as handles.) And you can just peel back the plasti-dip if you are not satisfied.
Use a hair dryer on low make a 4 hour job turn into 25 minutes...
Old May 9, 2009 | 05:51 PM
  #393
Jeffsmashkot's Avatar
Jeffsmashkot
Found these door handle covers..
Doing some Google searching, I came across a site selling chrome door handle covers. Hopefully they'll be decent quality. I ordered a set and I'll post my findings.
This is the site I found : https://bigboys-customtoys.com/store/AddCart.asp?ProdID={9E3D472E-E219-4C13-82E9-2753735B0479}
Old May 9, 2009 | 06:44 PM
  #394
wukusick's Avatar
wukusick
Thanks, I'll give it a try this week.
Old May 9, 2009 | 08:49 PM
  #395
MrCooperS's Avatar
MrCooperS
Moderator
Keep us posted on this.
Old May 9, 2009 | 09:27 PM
  #396
checkercoop's Avatar
checkercoop
Yeah it'll work like a charm. I did it on mine a while back to get rid of the gloss black. The plasti-dip looks perfect on it because it matches the black trim almost perfectly. Really pulls the design better and looks more like the R53 mirrors by having a better flow
The pic isn't that close, but you can tell how the mirror cap is no longer gloss and the whole side assembly flows better all matte instead of matte and gloss
[old pic]
Old May 9, 2009 | 10:10 PM
  #397
n733lk's Avatar
n733lk
I just completed my headlight rings and grill chrome the other night. 5 minutes to remove, 3 minutes to replace. All popped right off without any problem. Incredibly easy. The Plasti-dip works great. Just take your time and let it dry overnight before replacing.
Good luck!
Old May 10, 2009 | 09:19 AM
  #398
MichalKub's Avatar
MichalKub
What's the best way to do the door handles? Should I try and remove them or just blue tape everything around and start spraying? I've read that removing the doorhandles can be a real pita. I've got everything else plastodipped except the door handles, last step and most difficult. i could really use some advice here, thanks
Old May 10, 2009 | 09:39 AM
  #399
Jeffsmashkot
I think if you just put up newspaper (to avoid over spray onto the rest of the car) and stick index cards behind the black rubber/grommet, you'll be fine.
Just be sure to cut the plasti-dip away from the edges. Something I neglected to do. It ruined the whole job.
Not sure if someone has a trick regarding the keyhole though.
Old May 10, 2009 | 10:23 AM
  #400
MUShadd's Avatar
MUShadd
Yeah, tape up newspapers. then place index cards behind the edges of the handles. as soon as you apply your first coat, remove the cards, replace with new cards for the next coat and repeat process until you feel you have enough coats. The idea is to NOT let the plastidip have a chance to dry and make a bond to the handles and whatever you are masking with (in this case, index cards) because it will not want to separate.
