Interior/Exterior Mirror Knocked Off Help please
Old Apr 11, 2008 | 06:19 AM
SandiePepper's Avatar
SandiePepper
Okay someone tried to knock my driver side mirror off, they left it hanging. I put it back but it isn't really secure. Is there some secert to snapping into place? or is it brut strength? Anyone have pictures? so I can try to do this myself. it was knocked off at the base
Old Apr 11, 2008 | 07:19 AM
SandiePepper
anyone???
Old Apr 11, 2008 | 07:25 AM
Kentiki's Avatar
Kentiki
Do you have any pics?
Old Apr 11, 2008 | 07:28 AM
SandiePepper
I could get one, but it just got knocked off at the base and nothing is broken, it looks like it should just go back on.
Old Apr 11, 2008 | 10:00 AM
rkw's Avatar
rkw
Try this:
Originally Posted by ChiliRedS
If it is the mirror de attached from the base on the door(where the allen screws are now exposed) there is a silver pressure clip with little fingers on it that has to be pressed onto the shaft part of the mirror thats goes into the base. There is a spring that goes in between that clip and the mirror that keeps it from vibrating but allows it to be folded in toward the window. You will need to remove the 2 allen screws(at least they where allen on mine) and pull the base off. You should see the parts laying inside the base. I used a deep dish socket and a hammer to lightly tap the clip back onto the shaft. It doesn't have to be real tight. If you put it on too far the mirror will be difficult to fold.
Old Apr 11, 2008 | 11:29 AM
MidniteCoop's Avatar
MidniteCoop
This happened to me 7 days after i got my cooper, fold in your mirror and unscrew the 3 alen bolts. This will allow you to remove the mirror completely. What I used believe it or not was the hard plastic extension tube for a vacuum it was the same diameter as the pressure clip.
I simply put the pressure clip back in place and with the tube pressed to the floor and your hands on the top of the mirror, press on it until it is back where it should be, with the right amount of pressure.
Then re-mount to the car and you should be all set!!
Good luck and let me know how it turns out....
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
penguinplf
Oct 11, 2015 07:36 PM
Giants9595
Sep 29, 2015 10:49 PM
MCSNY
Sep 29, 2015 10:17 AM
