Interior/Exterior ALTA Gauges and Pods for R56
Old Feb 20, 2008 | 09:02 PM
  #26
mogollon8266's Avatar
mogollon8266
How accurate is the water temp from the overflow tank?
Old Feb 20, 2008 | 09:14 PM
  #27
masterd78's Avatar
masterd78
MANIAC
Slowboost, the boost adapter does fit with the stock box. I was worried about it too, but it fits.
Old Feb 26, 2008 | 07:43 AM
  #28
danielo's Avatar
danielo
Originally Posted by ADAMSALTAMINI
Let me see what I can do! Thanks for asking!
Hi Adam,
Any updates on the pic for the 52mm gauge mounted in the pod?
Old Feb 26, 2008 | 08:21 AM
  #29
lxjose9xl's Avatar
lxjose9xl
52mm gauge mounted.
Had to use the visor /cup that came with the pro-sport gauge and fab it up as an adaptor with some dremel work.
So unless Alta provides an adaptor the 52mm gauges don't fit.
Old Feb 26, 2008 | 09:16 AM
  #30
lxjose9xl's Avatar
lxjose9xl
So Adam from Alta clarified that they offer Spacer Rings for any client looking to use 52mm gauges.
Old Feb 26, 2008 | 06:04 PM
  #31
danielo's Avatar
danielo
Thanks for the pic. Noticed you used the single pod, i am assuming it's the same deal with the dual gauge pod that comes in aluminium.....
Still would like to see the alta pod with a 52mm meter with the spacer ring, i just wanna see for sure how it's gonna look before ordering the whole lot.
Old Feb 26, 2008 | 10:31 PM
  #32
danielo's Avatar
danielo
Originally Posted by lxjose9xl
52mm gauge mounted.
Can i get a peek at how it looks from behind the meters?
Old Feb 27, 2008 | 07:42 AM
  #33
lxjose9xl's Avatar
lxjose9xl
You can't really see much behind there since it's pretty close to the dash but i'll try to take a pic and post it on here.
Old Feb 27, 2008 | 03:14 PM
  #34
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Very! It isn't just an overflow tank. It is a reservoir that has fluid pass through it not just when the engine burps.
Old Feb 27, 2008 | 06:24 PM
  #35
danielo's Avatar
danielo
Thanks.
Maybe a pic taken from the side window or down from the windscreen would be great. Just trying to figure out how neat it is back there.
AWOL
Mar 28, 2016 10:51 AM
stierzy34
Sep 15, 2015 04:40 PM
Chasp
Sep 4, 2015 09:31 AM
Tylerlanger1
Aug 21, 2015 03:03 PM
