Interior/Exterior OEM or CF hoods
Old Jan 31, 2008 | 01:18 PM
  #26
UKSUV's Avatar
UKSUV
Originally Posted by 07BPB
Ok this is a bit out there. I sail small catamarans, and my boat has a bit of carbon fiber on it such as cross beams, carbon fiber mast etc. And well I always have to keep these things covered and protected from the sun because the UV rays tend to break up the carbon and make it deteriorate and lose its shine. Do the carbon fiber hoods have a tendency to want to deteriorate and lose their glossy topcoat?
YES...its not the CF that looks like that. Its the gel coating. Mine is starting to yellow to a greenish (Kevlar) color. You need to have you car, boat or whatever protected from the sun.
Old Apr 3, 2008 | 02:56 AM
  #27
KC Jr 54's Avatar
KC Jr 54
There is a 'special' clearcoat that has been developed to have this not happen. Of all places....Chevy and was designed namely for the New ZR1 vette of all things. Rather exspencive though....$6k a GALLON for the stuff.
Besides, painted Carbon Fiber is more baller.
Old Apr 3, 2008 | 11:14 AM
  #28
UKSUV's Avatar
UKSUV
Yeah...I read that in C&D (last issue I believe). That is some crazy stuff....
Old Apr 3, 2008 | 08:14 PM
  #29
Rhali's Avatar
Rhali
On the question on why the CF Hood doesn’t get as hot:
Fiber Reinforced Epoxy (CF) Thermal Conductivity: .0059 W/m*K
Aluminum: Thermal Conductivity: 180 W/m*K
Steel: Thermal Conductivity: 46 W/m*K
I think you can see how good of an insulator the CF reinforced Epoxy is.
On the UV and Epoxy issue. KC JR 54 is exactly right. You need to protect the Resin ( not the CF ) from UV light. UV light breaks down the polymer chains causing chalking, yellowing, and strength reduction over time. there are Marine grade resins to protect your epoxy.
GL
Rhali
Branto
Aug 11, 2017 05:32 PM
oeklm
Feb 17, 2016 01:00 PM
BRracing
Dec 22, 2015 09:25 AM
blackie
Oct 2, 2015 07:41 PM
FLYM1N1
Aug 16, 2015 01:15 PM
