Interior/Exterior quick question about charger/12v
recently had to loosen and move back the whole center console to get out my radio. last night i noticed the charger isnt working anymore. before i tear it back apart i wanted to see if anyone had any suggestions what might be wrong? and yes already checked the fuse. #32 if i remember correctly.
thanks.
thanks.
does it light up?
If you checked the fuse, most likely you displaced the connector on the bottom .... there r 2
One is power and the other is for illumination....do you have light around the ring?
You're probably gonna have to pull the console again. You 'can' pull the socket out, but the tab that holds it in place isn't real strong so it is easy to break.....especially by twisting....
But you're one up on me. When son had the problem I pulled the console apert first THEN checked the fuse....
