Interior/Exterior driving lights...cheaper alternative?
Old Jun 29, 2003 | 02:30 PM
GB_Junkie's Avatar
GB_Junkie
After seeing pictures of Mini's with auxiliary driving lights, I decided that I would like to have some. I looked around and it seemed like I would have to spend around $400 for two lights?!?! For that sort of money I can get 6 auxiliary lights on my Land Rover. So, I was thinking, couldn't I just buy the brackets from Mini USA and add different (cheaper) lights? Also is it possible to add 4 lights to the front?
_________________
Mel A.
just a warning...you're talking to a 18 year old
2003 Mini Cooper S (DS, packages 1,2,3, HK)
1995 Land Rover Discovery (for sale)
1974 MGB
Old Jun 30, 2003 | 03:43 PM
jcs's Avatar
jcs
yes, but the MCO brackets & harness & switch & cheaper lights = $400 or more (
good luck.
Hella and PIAA are good alternatives - still did not get mine (
go to search and look for driving lights or rally lights.
Old Jun 30, 2003 | 06:42 PM
Flash's Avatar
Flash
Try JC Whitney
Old Jul 1, 2003 | 10:07 PM
darwinLLM's Avatar
darwinLLM
Try the PIAA 520-X at NMC
Old Jul 3, 2003 | 04:11 AM
Moorlockx's Avatar
Moorlockx
The brackets run about $40 from Classic Mini. You can also get a harness from them for around $120, unless your experienced enough to make your own. A good set of lights can be found for around $100 (there's cheaper ones out there though.
If you're doing just 2 lights they can easily be wired in directly to the high beams. I would run a separate system if you're going to use 4.
Old Jul 3, 2003 | 05:35 AM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
If you do a 4 light setup, be careful how you wire them up. You can find yourself with a nice ticket using all the lights at once in the wrong place.
Old Jul 4, 2003 | 08:14 AM
KAR120C's Avatar
KAR120C
Not cheap, but another solution and they have a 4 light option:
http://www.mossmini.com/Shop/ViewPro...eIndexID=34609
For about the same money as the dealer option you can get 4 lights instead of 2.
Has anyone tried this product? How easy is it to install?
Dec 5, 2016 06:31 PM
xpunisherx
Aug 10, 2015 10:50 PM
nismo4life
Aug 5, 2015 08:31 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
