Interior/Exterior Removing Interior Trim Panel on R56 Hatch
I need to remove the interior trim panel on the hatch to do some wiring. I can only see 4 Torx bolts holding it on. I imaigne there are also some clips. Is that all there is to removing it? Once removed, I assume the existing wiring will be readily visible. Or will I be in for some surprise? Thanks!
Looking at the www.realoem.com layout for the trunk lid there is four clips top and bottom, eight total. Just use a broad blade and some hand pulling to pop them out, starting at one corner. When replacing, just line them up one at a time and pop them in with your fist. It will help to have a second person there to hold it as you will be working upsidedown. BTY, There is two types of clips on there.
Looking at the www.realoem.com ...
Has anyone actually removed the hatch interior pannel on the R56? The diagram from realoem looks accurate (I put in the last build date option it listed), but after removing the Torx bolts, it still seems held very firmly. I know there are clips, but I don't want to exert too much pressure until I am sure I doing it right. Anyone?? Thanks!
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
