New Forge Blow Off F66+ | New Sneed4Speed Forged Pistons
Old Jun 20, 2025 | 01:39 PM
ECS Tuning
New Forge Blow Off Valve F66+ / F65+ 2025+This valve is a fully engineered solution offering significantly improved reliability, due to its piston based design with no diaphragm to fail and full aluminum construction. It replaces the original unit with a pressure/vacuum operated piston valve that retains the desirable OEM ECU control over valve actuation. Furthermore, heavier springs are available and are easy to swap in, to suit your tuning needs if you add more boost pressure to your vehicle.
  • Precision manufactured springs for more precise operation and consistency
  • Made in the UK, ensuring top quality
  • Faster response times and longer service intervals
  • A super durable and responsive aluminum piston that uses heat resistant Viton O-rings
  • Lubricated with high temperature Mobil1 grease to ensure a long life with minimal wear and very long service intervals
  • Fully serviceable and rebuildable in minutes
  • Unlike other valves on the market this will not cause a CEL
And Free shipping!
"Click HERE for the MINI Cooper Forge BOV!
New Sneed4Speed Forged PistonsW11 and N14 Engines!
Crafted with precision and expertise, our forged pistons are built to withstand the most demanding conditions and deliver exceptional power, reliability, and durability.
The key to the superior performance of our forged piston lies in its construction. Each piston is meticulously forged from high-quality, heat-treated aluminum alloy, ensuring incredible strength while maintaining a lightweight design. This optimal balance of strength and weight allows for faster acceleration, improved throttle response, and enhanced overall engine efficiency.
Our forged pistons are engineered with advanced features to maximize engine performance. The specially designed skirt profile reduces friction and enhances piston stability, minimizing wear and increasing longevity. The piston crown is carefully machined to exacting tolerances, promoting efficient combustion and optimizing power output of boosted engines.
To ensure the highest level of performance, our forged pistons undergo rigorous quality control measures. They are subjected to comprehensive testing, including dimensional accuracy, material integrity, and thermal stability, guaranteeing consistent performance and reliability.
Whether you're a racer seeking the ultimate power upgrade or a performance-driver looking to enhance your engine’s capabilities, the Sneed high-performance forged pistons are the ideal choice. With their exceptional strength, lightweight design, and advanced features, they are engineered to withstand the demands of high RPMs, high boost, extreme temperatures, and intense race conditions.
These pistons are designed to fit Sneed connecting rods but will also fit all other OEM and aftermarket connecting rods. Complete set includes pistons, rings, wrist pins and locks. Fit OEM, Sneed and all aftermarket rods
And Free shipping!
"Click HERE for the MINI Cooper Sneed4Speed Pistons!
Old Jun 21, 2025 | 04:57 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Sneed is back?! Oh man…
https://www.northamericanmotoring.co...d-4-speed.html
Jonathan Jones
May 7, 2021 09:40 AM
Systemlord
May 3, 2019 04:43 PM
WayMotorWorks
49
Jan 30, 2015 09:51 AM
fozworth
Mar 24, 2007 10:39 PM
