JB4 Performance Tuning for F5X Mini!!
Old May 31, 2019 | 10:27 AM
mike@n54tuning.com's Avatar
mike@n54tuning.com
MINI B38/B46/B48 JB4 Performance Tune With OBD
Direct Order Link
https://www.n54tuning.com/mini-b38/b...ance-tune.html
Ready to take your MINI B38/B46/B48 turbo to the next level?
How about up to 40hp to the wheels (50hp crank) on a completely stock B48 on pump gas? The JB4 features a simple plug and play installation harness for easy installation and includes many features not found on any other tune. Including on the fly in dash map switching between factory and various performance maps, optional in dash gauge displays for boost, boost limiting by gear for improved traction in lower gears, E85 fuel support, progressive water/methanol support, built in data logging, built in code reading, and much more.
Remember the JB4 does not require any additional modifications or previous stages. Simply install the JB4 as your first and only modification and enjoy an entirely new fast and smooth racing experience. The JB4 also does not require any user setup or customization but for more advanced enthusiasts the BMS DATA cable allows you to connect via a laptop for data logging and free software updates. Made in USA. 5 Year Warranty.
Wirelessly connect the JB4 to your Bluetooth 4.0 compatible iOS and Android device via the JB4 Mobile connect kit, or to your Windows laptop with the BMS data cable. Both options allow you to record and analyze vehicle and tuning data, change JB4 performance maps, and update JB4 firmware as we release free newer versions with updates, more powerful maps, and new features under development. Separate JB4 Mobile app purchase also required.
The latest B38/B46/B48 map guide, feature set, firmware updates, and directions are posted here.
Applications:
• 2014+ MINI S B38/B46/B48
FEATURES AND BENEFITS
• Power gains of up to 40hp to the wheels on a stock vehicle
• Quick Plug & Play Installation
• CANbus integration offering unrivaled tuning features and performance
• Runs as smoothly as stock, this is how your MINI should have come from the factory
• Compatible with all driving modes
• Fuel economy unchanged during normal driving
• Compatible with JB4 Mobile for smartphone logging, tuning changes, and adjustment
• Ethanol (E85) compatible tuning maps
• Able to read/delete fault codes
• Not VIN locked, can be removed without a trace and resold down the road
• Made in the USA
• Free USA Shipping
• 5 Year Warranty
VIDEO
Josh/AWE
Mar 21, 2016 02:06 PM
Josh/AWE
Mar 21, 2016 12:35 PM
