CTS Turbo Now @ ECS | F56+ Module Tuners
Old Jan 24, 2017 | 02:45 PM
ECS Tuning
CTS Turbo For Your R55-R59 MINI
CTS Turbo Performance Cold Air Intake System produces horsepower/torque gains by replacing your vehicle’s restrictive factory air intake housing. This air intake system was designed, tuned, and dyno-tested to fit specific MINI Cooper S/JCW systems. Air enters the system through an oversized synthetic washable air filter for outstanding air flow, filtration, and performance. CTS turbo also carries a matching Blow Off Valve to project the turbo sound and silicone hose to clean up the airflow to and from the intercooler.
Increase Power and Boost
Fitment:
R56 MINI Cooper S '07-'10/JCW '09-'12
R55 MINI Clubman S '08-'10/JCW'09-'12
R57 MINI Cooper Convertible S '09-'10/JCW '09-'12
R58 MINI Coupe' JCW '12
R59 MINI Roadster JCW '12
Click HERE For MINI Cooper Options
MINI F54-F57 Performance Module Tuners
These boost controllers were designed from the beginning to be easily installed and even easier to use. It plugs into a sensor and uses the factory DME to re-map boost, timing, and fuel maps. Changes can be made via Bluetooth the Dinan, allowing you to use your smartphone to turn boost up for max performance or down for conservative driving. Changes on the NM module can be done with a switch on the module itself.
Up to 30Hp 40lb/ft gain on the Dinan or 44Hp 34lb/ft (on 100 octane) on the NM Engineering module.
Two great leaders in MINI performance parts, continuing in the Gen 3 MIN
Power Up!
Fits:
F54-F57 MINI Cooper /S/JCW 14'+
