Mini Cooper Driving Lights Application Guide
Old Sep 4, 2015 | 02:34 PM
Mini Mania's Avatar
Mini Cooper Factory Driving Lights Application Guide
The MINI Factory Driving Light system consists of several modules:
  1. Driving Lights - with Harness
  2. Mounting Brackets - With modified Grille on most models
  3. Switch Module - Available in different colors
  4. Interface Module - F55 & F56 models with LED Headlights only
In order to replicate the MINI factory installed driving light option, you must order one each of items A, B and C.
Item D is only necessary on the 2014+ F series Hardtop with the LED Headlight option.
NOTE: The MINI Factory Driving Lights have a unique mounting system that requires the factory mounting brackets - these are not the standard 'post mount' type lights.
The factory lights ARE NOT COMPATIBLE with aftermarket brackets, and aftermarket driving lights ARE NOT COMPATIBLE with the factory mounting brackets.
Get the factory lights WITH factory brackets, or aftermarket lights WITH aftermarket brackets. (Click on the follwoing link for the Application Guide.) http://new.minimania.com/Mini_Cooper...lication_Guide
Wohnson89
Jun 10, 2020 04:53 AM
jrezzo
Aug 9, 2015 10:32 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
