:: ECS Tuning :: MINI R58 R59 N18 Forge Diverter Valve Upgrade
Old Feb 18, 2015 | 06:25 AM
Stock diverter valves just can't handle performance upgrades. Add a little boost and they get all weak in the knees and go to pieces.
Forge knows this. That's why they've engineered boost-hardy blow off and diverter valves tough enough to take the pressure without blowing their lids.
If an ECU upgrade or other engine aspiration upgrade has significantly altered your manifold boost pressure, or if you're looking to stave off future diverter valve failures, the Forge kit is the wisest solution.
Forge has even included an install PDF on a flash drive to make installation simple.
Forge Ahead.
Fits: N18 engines
R58 MINI Coupe' S (2012+)
R59 MINI Roadster S (2012+)
Click HERE For the Forge kit
Aug 7, 2015 05:56 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
