How To Maintenance :: Oil Change How-To
Old 11-13-2006, 03:30 PM
goldcountrymini's Avatar
goldcountrymini
goldcountrymini is offline
Just finished my oil change over the weekend. Thanks to Randy & NAM! Couldn't do half of the stuff without all of you!
  #102
Old 11-14-2006, 07:13 AM
Ranzo's Avatar
Ranzo
Ranzo is offline
Originally Posted by obehave
All I can say it that isn't typical.
I've done at least5 DIY oil changes on my car and never seen that.
Oh dear... What do you think is causing it?
Okay here is a better description...
At cold starts, the check engine oil light is off. When it worms up a bit, the light comes on when the engine is at idle. But when I step on the gas it turns off.
  #103
Old 11-14-2006, 07:36 AM
obehave's Avatar
obehave
obehave is offline
That sounds very much like low oil pressure.
I wouldn't put a lot of faith in an idiot light but would definitely look into it.
  #104
Old 11-14-2006, 10:16 AM
golfersmurf's Avatar
golfersmurf
golfersmurf is offline
It does sound like low oil pressure. Assuming the oil level is correct maybe it's the filter? Did you change your oil filter when you changed your oil? (I hope so!) You didn't mention it specifically...if so maybe it's not installed correctly?
The filter's are a little odd/tight compared to some other canister types...
  #105
Old 11-14-2006, 10:42 AM
Ranzo's Avatar
Ranzo
Ranzo is offline
Yes I also changed the filter...
But I think I might have found the problem.
http://www.promini.com/technical/tec...oil_filter.php
I'll double check the filter tonight.
Thanks for your help.
Randy
  #106
Old 11-14-2006, 10:51 AM
MiniMaybee's Avatar
MiniMaybee
MiniMaybee is offline
Tossing that center piece is easy to do. I had to go fishing mine out of the trash the first time too. Hope that is the problem.
  #107
Old 11-15-2006, 07:59 AM
Johnna's Avatar
Johnna
Johnna is offline
Originally Posted by FraserBonnett
Nice job, and thanks for all the effort you put in to make it so easily understandable.
My wife thinks I can just take my Mini to the Valvoline Quick Lube place ... NOT
I agree with "NOT" because I actually did go to the Valvoline place where I take my wifes car. I showed up with filter in hand and they said that they were not allowed to work on MINIs. Evidently they had a bad experience with one. I feel bad for the poor MINI owner that experienced the problem first hand but I'm glad it wasn't me! I've been doing my own ever since.
  #108
Old 11-15-2006, 06:19 PM
apexer's Avatar
apexer
apexer is offline
Originally Posted by Johnna
I got one of those drain plugs with an operable valve from Moss MINI. When combined with a fairly shallow drain pan, I found that I didn't need to jack the car up to drain out the old oil.
http://www.mossmini.com/Shop/ViewPro...31&SortOrder=1
When I had it installed at Schomp during a scheduled oil change, the MA pointed out that they have had to remove a couple due to leakage. I've been checking mine and it's fine so far.
I don't have one on my Mini... yet... but I have used them in the past and never had, or even heard of a leaking problem with this valve.
  #109
Old 11-17-2006, 05:41 PM
ahamos's Avatar
ahamos
ahamos is offline
Coordinator :: River City Minis
What about if you have the auxiliary gauges? The oil-temp sensor IS the drain plug on my car; I'd imagine the valve doesn't have a provision for replicating that functionality.
  #110
Old 01-05-2007, 06:13 PM
toecutter's Avatar
toecutter
toecutter is offline
oil spillover??
OK, total Mini newb here, I was all set to pick up my new (to me) 03 MCS this afternoon, but after the mechanic inspected the car, they detected oil leaks around the area of the oil cooler. When this was pointed out to the dealer, he explained that he had changed the oil several days prior, and the canister type filter spilled oil everywhere. He degreased the oil cooler, and is going to have the car looked over at the local Mini dealership. My question is: a. is this plausible? b. are oil leaks common occurences with these motors? c. what types of problems are common for this year/model? I drove the car from the dealership to the mechanic, and I can honestly say that I am already in love... I can't wait to pick er up!!
  #111
Old 01-05-2007, 06:27 PM
Crashton's Avatar
Crashton
Crashton is offline
Welcome to NAM :-)
Mine doesn't have an oil cooler & I believe a 2003 doesn't either. What I think your mechanic is referring to is the oil filter adapter that mounts on the rear of the engine. What the dealer told you is very plausible & highly possible. The filter is mounted with the opening facing down. If one loosens the filter a bit & waits it will drain out & not leak. A dealership mechanic isn't going to take the time & wait, not if he's paid flat rate & most are. I haven't seen many reports of oil leaks on MINI's & don't believe it's much of a concern. Enjoy your MINI. Happy motoring.
  #112
Old 01-06-2007, 04:25 AM
toecutter's Avatar
toecutter
Oil Pump
Maybe it was the area around the oil pump, directly below the filter. There was something that looked exactly like the oil cooler on my Ducati... Anyways, the oil was all over tht area, and also the front suspension. The foreign auto mechanic said that they didn't think that it was from spill over. Hopefully when the mini mech looks it over everything will be OK. I got a great price on this car, I hope that it's not because of a huge engine problem!
  #113
Old 01-06-2007, 07:09 AM
ahamos's Avatar
ahamos
ahamos is offline
Or maybe they sliced the O-ring when they installed the filter. I've done it. It sucks.
  #114
Old 01-06-2007, 05:42 PM
Bullfrog's Avatar
Bullfrog
Bullfrog is offline
Yah, I too have sliced the O ring putting the new filter on. Big mess. Good thing I had a spare.
I believe at some point the Coopers stopped using that plastic insert thing that can get thrown away, mine doesn't have one. I don't know at what point they changed, though.
  #115
Old 01-06-2007, 06:26 PM
MLPearson79's Avatar
MLPearson79
MLPearson79 is offline
Thanks for this how-to! I just finished changing my oil and it went very smoothly with no problems and not a drop spilled
  #116
Old 02-17-2007, 01:46 PM
Hangin'_with_Mr.Cooper's Avatar
Hangin'_with_Mr.Cooper is offline
Oil Filter Tip:
I just finished my 1st oil change on my used 2003 MCS. I bought a 36mm shallow socket, MANN oil filter & 5qts of 5w-30 Mobil-1. My car liked all 5 qts...it seemed just right.
I just drove my car up on ramps and had no problems with clearances. Now my oil drain plug was very tight and my oil filter was extremely tight. I had to use a breaker bar on that one for sure.
One tip that I haven't seen anyone in this post (any maybe I missed it) was something I noticed myself when trying to loosen/tighten the oil filter:
From under the car, you can get your socket wrench in through the passenger side fenderwell area and onto the oil filter. But you would still be removing and installing the oil filter through the top of the motor. I found that I could line up the oil filter and actually see what I was doing from under the car much better than from the top where you also have limited movement for your socket.
Now, I'm not sure if the suspension would get if your way if you use jacks instead of ramps? But this method worked well for me.
Please excuse how dirty my car was in these photos.
Passenger side fenderwell
  #117
Old 02-23-2008, 02:42 AM
muladesigns1's Avatar
muladesigns1
muladesigns1 is offline
Originally Posted by RandyBMC
SMKKVK,
I haven't researched whether or not there are benefits to using a canister, but I know that BMW has used this method for some time. My personal opinion is that they do it to keep you going to the dealer for parts.
As for the plug seal, it's neither o-ring nor copper. It has a built-in hard plastic mating surface - unique, eh?
Let me know if you have any other questions.
Randy
my 07 mazda 3 has the same canister type filter as well.oh and as far as the engine being BMW engineered, the first generation has the chrysler neon based engine in it, ive heard
  #118
Old 03-16-2008, 05:06 PM
brl182.benjamin@gmail.com's Avatar
brl182.benjamin@gmail.com is offline
haha, i dont know how lockjawdavis got one for 75 bucks, mine was 245, but since then its not worth it so i just do it myself.
  #119
Old 04-13-2008, 08:30 AM
bmackinlay4353's Avatar
bmackinlay4353
bmackinlay4353 is offline
Randy, appreciate your tutorial, now if I can do it !! Will know in a little bit!! Bill
  #120
Old 04-13-2008, 08:45 AM
javelina1's Avatar
javelina1
javelina1 is offline
you'll do fine. confidence!
  #121
Old 05-18-2008, 06:57 AM
101101's Avatar
101101
101101 is offline
4.7 (5 is OK) quarts of 5W30 full synthetic (I prefer Redline - Amsoil and Motul are great too)
Is this capacity the same for MC and MCS?
  #122
Old 05-18-2008, 07:12 AM
nigelthecooper's Avatar
nigelthecooper
nigelthecooper is offline
How does one reset the oil change interval after the oil change? Does it do it automatically or is there some reset on the clock/miles meter? Haven't changed my own oil yet, but willing to try.
'06 MC BRG/White. "Nigel"
Magnaflow Catback, K&N Typhoon CAI
  #123
Old 05-18-2008, 08:35 AM
chadtoolio's Avatar
chadtoolio
chadtoolio is offline
YOu can install the filter from up top, but you can see if the o-ring is bunching up when screwing the filter in if your looking at the whole housing from the bottom.
  #124
Old 05-18-2008, 10:16 PM
Ancient Mariner's Avatar
Ancient Mariner
Ancient Mariner is offline
With thanks to Davester:
1. Push the Trip Button
2. Turn ignition key to position 1 and 51A will appear to left of mileage
3. Release trip button
4. Wait 3 seconds
5. Push trip button
6. Wait (5-8 seconds) for RST to appear in left corner
7. Release trip button
8. Push trip button
9. 15000 will appear as new service interval
10. Release trip button
  #125
Old 05-18-2008, 10:28 PM
ScottRiqui's Avatar
ScottRiqui
ScottRiqui is offline
I've seen the OBC-reset directions before, but I've always wondered about something:
As the car accumulates miles from new, the OBC appears to cycle through a series of four events:
1) Oil Service
2) Inspection I
3) Oil Service
4) Inspection II
Presumably, after you complete Inspection II, the cycle begins again.
My question is, when you reset the OBC, can you tell it exactly where in the sequence you are? In particular, let's say you buy a used car with 30,000 miles that has never had the OBC reset. So, it's saying that "oil service" is due, with something like "-18,000" in the service counter. So you go ahead and have the oil changed, along with having all of the Inspection I items done. If you just reset the OBC, won't it incorrectly start counting down to "Inspection I"? At this point, you'd want it to start counting down to "oil service" (the third service in the sequence).
Can you just reset the OBC twice in succession to skip over the "Inspection I" countdown and get it counting down to "oil service"?
Quick Reply: How To Maintenance :: Oil Change How-To
