How To Serpentine Belt Replacement DIY Tech Article by Pelican Parts
Old Apr 23, 2013 | 01:30 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
It’s always a good idea to check your serpentine belt at every oil change for cracks which would be visible on the underside of the belt. This belt is very important as it drives accessories such as water pump (non-S), supercharger/water pump (S), alternator and A/C compressor.
We’ve put together a detailed DIY Tech Article for you with step-by-step info as well as great pictures. You can check out the article here:
MINI Serpentine Belt Replacement
Go For It!!
888.280.7799 | 6am - 5pm PST
maestro39
Oct 27, 2015 02:38 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
