MINI GP2 Track Build for Watkins Glen
Old 08-03-2018, 08:04 AM
Eddie07S's Avatar
Eddie07S
Eddie07S is offline
Received 1,136 Likes on 891 Posts
Drew,
Do you know what size front sway bar the GP came with?
OK, you asked for it. I am not a fan of just a big RSB. It throws the balance of the car of off. MINIs really like trailbraking, especially T1 at WGI; I am told I am getting close to the apex with my trailbraking on that corner. Trailbraking adds a lot of grip to the front of the MINI and takes grip away from the rear of the car. Adding a big RSB, without the balance of a larger front bar, further removes grip from the rear. That loss of grip in the rear can be harmful. Typically, the way to counter act this is to get on the gas before the apex, which adds a bit of understeer and is not the fastest way around the track. Randy Pbost has written a lot about this. So, my suggestion is to start at the lowest setting and be really careful with trailbraking and run the rear shocks a bit on the softer side. I have seen what the WGI guardrails do to cars that have too much oversteer built into them, including video of an instructor who went into oversteer situation in T3 (the esses) at about 105 in his BMW. I have also hit antifreeze in this turn. This is why I run the big FSB with the RSB; I didn’t spin the car when that happened. I have also seen this combination in the ST class MINIs in the IMSA races.
Drewalbiston (08-03-2018)
  #77
Old 08-03-2018, 08:10 AM
Drewalbiston's Avatar
Drewalbiston
Drewalbiston is offline
Originally Posted by Eddie07S
Drew,
Interesting. I will tell you how it goes. If it is awful then I will make some corrections. You gotta experiment and have fun.
Thank you for that though.
Drew
  #78
Old 08-03-2018, 08:11 AM
favino1006's Avatar
favino1006
favino1006 is offline
Drew,
SUPER good advice..
  #79
Old 08-03-2018, 08:52 AM
Eddie07S's Avatar
Eddie07S
Eddie07S is offline
Drew
I have a friend with a MINI S, the 22mm RSB and your shocks. He was able to run it on the Lime Rock Park skid pad and their autocross course (go-kart track) and was able to experiment with it. When he started, I think he called it dangerous. I think he went with full stiff up front and full soft in the rear on the shocks (or close to that) and came away with smiles. He was on either the stiffest or middle setting on the bar. So, yes, I agree, experiment. And it can be made to work. Just be careful.
  #80
Old 08-03-2018, 12:23 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
UPGRADE #7, Hotchkis Sport 22mm Competition Sway Bar.
My seventh mod for the car is the 22MM Hotchkis Sport comp sway bar. I originally ordered the 22MM sway from Alta to match my rear controls and end links. The part though was on back ordered, so Way over at Way Motor Works suggested I get the H-Sport Comp bar for my car instead. $200 dollars in overnight shipping the part was here.
The Mini GP comes with a 19MM sway bar originally. I think the 22MM is going to be a huge increase in the car's capabilities. Especially in corner entry in the exit. The GP though has a really good balance of the rear in a corner. With threshold braking, you can rotate the car just as you would like. Now I believe the It'll be that much better. I am going to set it to the medium setting and see how it goes. If it feels too soft or too tight, I may change it. I know on my second day I have a 45-minute enduro so I will be experimenting with the rear from racing lines to braking points.
The H-Comp bar is a hollow bar unlike most that are solid. From what Way says this bar almost saves 8lbs pound over a solid bar. This bar weighs 5.5lbs. '
Actually the stock GP rear sway bar is 18mm not 19mm.
And the Hsport Comp rear sway bar is 25.5mm hollow which is the same stiffness as a solid 22mm rear sway bar just without the extra weight and much higher quality bushings and material.
The average solid 22mm rear sway bar is 13-14lbs and the Hsport comp bar is 5.5lbs so a big savings. Also our WMW Hsport comp bar is grey powdercoat to match the GP
https://www.waymotorworks.com/wmw-rear-sway-bar.html
It's the ideal bar for all Gen1 and Gen 2 Cooper S. I tell everyone to start with it on the middle setting and go stiffer if they want, but 99% of people just love it on the middle and never change.
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
  #81
Old 08-04-2018, 02:55 AM
robbo mcs's Avatar
robbo mcs
robbo mcs is offline
Drew,
Wise words FWD cars tend to have inherent understeer problems. The common solution to this is to do something that loosens the rear end and induces lift off oversteer. This makes the car "feel" better and faster. In fact what has happened is you have decreased the grip at the rear end. The best way to fix understeer is to actually fix the front end of the car, give the front wheels more grip and stability. This will actually make the car faster.
To the OP, you actually have done a lot of the right things to improve the front end, better shocks, appropriate alignment adjustments, bushings etc. Other things available to improve the front end grip include appropriate ride height front to rear (rake), tire pressures front vs rear, spring rates and damping adjustment both overall and front rear balance.
  #82
Old 08-06-2018, 04:54 AM
MrBlah's Avatar
MrBlah
MrBlah is offline
6th Gear - AX Champion
I too stiffen the front, I do not like big swaybars because of FIA curbing so I do it with more spring. I stiffen the back too though with an adjustable bar and stiffer springs, I ended up with 8kg/mm front and 9kg/mm in the rear on my track car. It'll lift oversteer but it's very progressive and easy to work with and I can take some out by softening the rear bar. Without stiffening the front the mcpherson sucks design loses too much camber
  #83
Old 08-06-2018, 06:51 AM
Eddie07S's Avatar
Eddie07S
Eddie07S is offline
When I watch the IMSA races they talk about different setups for different tracks and how, not having past history for a particular track, they experience difficulties in coming up with a fast setup. I didn’t think much about that until I put really good shocks into my car. It was then I really noticed the impact that really good equipment has on the feel of the car. I found tha the Bilstein B8s are really good for WGI. However, I found that they are a bit soft for LRP. If I had adjustable shocks I would start my setup for WGI a bit on the softer side overall and see how that goes. One reason I bought non-adjustable shocks was to not have to deal with the combinations and permutations that come along with adjustable shocks, until I had more experience with the car. It appears that now I have the experience I need to make good use of adjustable shocks; maybe it is time for another mod....
  #84
Old 08-06-2018, 08:02 AM
MrBlah's Avatar
MrBlah
MrBlah is offline
I have double adjustable KW, but I really want some 3 way so I can adjust low speed compression too, only thing is 3 way are $$$$$$$$ it'll be driving a 5000 $ car with 4500 $ suspension
  #85
Old 08-06-2018, 09:26 AM
Eddie07S's Avatar
Eddie07S
Eddie07S is offline
Oh, way to many options for me...
The Ohlins are nice as they adjust both jounce and rebound, together, with the one **** (if I remember correctly), which removes an option for me. At this point, that is infinitely more adjustment than I have now... Works for me for what I do.
Hmmmm, do I see a set of ASTs in your future, MrBlah? It’s only money...
  #86
Old 08-06-2018, 10:32 AM
blue al's Avatar
blue al
blue al is offline
If we are spending other people's money how about some lighter wheels?
perhaps with a mixed et for extra track width, it will help suspension with reduced weight and front rear balance as well
sorry for off topic, but could be a good investment if your car will continue to do lots of street duties as well.
i just purchased some OZ ultraleggera, they are light and clear the calipers
  #87
Old 08-06-2018, 11:17 AM
RB-MINI's Avatar
RB-MINI
RB-MINI is offline
Duplicate post.
  #88
Old 08-06-2018, 11:22 AM
RB-MINI's Avatar
RB-MINI
RB-MINI is offline
Thank you Eddie.
I will be getting the JCW Euro Recaros this winter. Probably going to have to get them custom stitched to say JCW, but oh well. Also, I will be getting a half cage for it this winter too. I know safety should be first. Just as you know you are talking around 7k-8k for seats, cage, and harness plus the labor too.
For the Scan gauge, I am going to order that today. Good to have it in the car. I think it is crazy these cars never came with any gauges.
Thank you.
The R56 JCW Recaro’s have the JCW logos already, embossed in leather or embroidered on alcantara. They apparently had 1st gen logos available on these too, but they were NLA by the time I ordered a pair for an R53.
Originally Posted by MrBlah
watch out with the recaros, you will need 5 or 6 point harnesses, most groups ban 4 point now, I'm not sure those factory seats have a pass through. I went with sparcos on sliders and a half cage, and 6 point harnesses and it was less than 2000 for everything. The only thing I got used were the seats and harnesses, expired is fine for HPDE with every group except porsche last time I checked, expired seats are always ok with a extra brace even for wheel to wheel.
I got quotes on custom weld in half cages and they were 900-1500 installed, I went with a hard dog bolt in.
Why the need for 5 or 6 point harnesses with the Recaro JCW’s? They’re basically the same as regular seats, but no passenger occupancy sensor. They still even have side airbags and seat heating.
edit: I probably didn’t understand the post correctly. Are the harnesses for a class/track requirement and not due to the style of the seat?
  #89
Old 08-06-2018, 11:33 AM
MrBlah's Avatar
MrBlah
MrBlah is offline
I got the impression that you were going to track the car, roll bar plus 5/6 point plus Hans all go together I would not do one of the three without doing all three you risk moving around too much with a stock belt ie ending up tangled in the bar.
and it's exhausting on the track trying to hang on.
  #90
Old 08-06-2018, 12:02 PM
RB-MINI's Avatar
RB-MINI
RB-MINI is offline
Not the original poster, but was curious and later figured out the harness recommendation was for the intended track use. The euro JCW Recaro’s are just Sportster CS’s and there’s a seller on eBay who refurbishes them, along with custom upholstery options. They also offer an anti-submarining belt option for the lower cushion. Not sure how cutting out the hole affects the integrity of the seat in a crash since it wasn’t part of the original design, though.
For track use I would definitely get alcantara over the slippery leather version.
  #91
Old 08-06-2018, 12:15 PM
Eddie07S's Avatar
Eddie07S
Eddie07S is offline
If you retain the factory seat belt buckles front and rear you can use the Schroth Quickfit (4 point) belts, even with a roll bar and the Euro JCW seats (I had a set of those in my first MINI). Because the Schroth QuickFit is DOT legal it is accepted by the event organizers (BMW, PCA, etc.) around here. However, an individual instructor may opt to not use the Quickfit if you don’t have a roll bar. In that case you are required to use the 3 point belts (requirement for equal restraint for both you and instructor) and I have a set of CGLocks that I install for them.
  #92
Old 08-06-2018, 12:22 PM
MrBlah's Avatar
MrBlah
MrBlah is offline
I had a set, I much prefer the 6 point expecially with the Hans
and they are cheap, unless you want brand new ones for w2w racing
  #93
Old 08-06-2018, 12:49 PM
Subw00er's Avatar
Subw00er
Subw00er is offline
This stiffer FSB discussion is interesting to me. I put on a 25 hollow rear bar and have it on stiff. I like the feel and tendency to over-steer, but I've lost some corner entry balance and willingness to turn. I'm assuming this is the loss of camber up front as the suspension works (as mentioned). I'm strongly considering going to a larger FSB, but I'd like something adjustable and not TOO much stiffer, I just feel like I need 15% or so more to balance out the rear. I tried the rear on medium, but I prefer the stiff setting - I just feel like the front needs some attention now.
What FSB would be a good choice to mate with the Hsport 25mm? I also have koni SAS and very sticky tires (see sig).
  #94
Old 08-06-2018, 01:42 PM
blue al's Avatar
blue al
blue al is offline
there is a jcw factory sports bar at 24mm,
the gp is thinner 23.5mm.
somone somewhere thought it needed a little bit extra available for r58 coupe and r55 jcw sports suspension
otherwise I think after market fronts are 25/26/27 dependent on brand
  #95
Old 08-06-2018, 04:01 PM
Eddie07S's Avatar
Eddie07S
Eddie07S is offline
Hope the OP doesn’t mind we have gone off topic on his thread, again.
I believe the H-sport 27mm front bar is hollow and is less stiff than the 24 mm bar JCW Sport bar and just slightly stiffer than the 23.5 mm GP bar. I am running the 27 mm solid bar with the IE fixed camberplates up front; 25 mm H-sport in the rear on the softest setting. This has great control over the front camber, turn-in and just turning. And the ride is fine, with good shocks.. The softer you go, the less resistance to the camber change. So I would add the 24 mm JCW bar in betweeen the 25mm bar and the 26mm bar.. Not sure if this helps, but those are your options for front bars.
The following 2 users liked this post by Eddie07S:
blue al (08-06-2018), Subw00er (08-07-2018)
  #96
Old 08-07-2018, 08:21 AM
Subw00er's Avatar
Subw00er
Subw00er is offline
Sorry , OP! But this is still really good discussion I'm sure he can learn from!
I am not sure what bar I have.. I have a factory JCW, but its a r52 and I know at least the shocks from the factory are not the same as the r53.
  #97
Old 08-07-2018, 11:53 AM
Eddie07S's Avatar
Eddie07S
Eddie07S is offline
If you have black springs you most likely have the 23.5mm front bar. See Way Motors post below. I believe the 26mm bar is adjustable; the 27mm bar is not. Also, when you look at the percent stiffness, those percentages are likely in relation to the 22.5mm bar that the S comes with. Also, the stiffness of a bar is relative to the radius to the 4th power, so that 0.5 mm different between the 23.5 and 24mm bars is worth almost 9%.
  #98
Old 08-07-2018, 01:32 PM
ECSTuning is offline
Received 1,966 Likes on 1,766 Posts
Hope to do another track day at Pitt Race soon, did you get up there when you were here for the PVGP?
  #99
Old 08-07-2018, 02:15 PM
WayMotorWorks
Vendor
Since you have an R52 S you will have a 24mm front bar as that was the standard bar for all R52 S
Subw00er (08-08-2018)
  #100
Old 08-08-2018, 11:38 AM
Eddie07S's Avatar
Eddie07S
Eddie07S is offline
I believe the H-sport front bar is hollow and is less stiff than the 24 mm bar JCW Sport bar and just slightly less stiff than the 23.5 mm GP bar. I am running the 27 mm bar with the IE fixed camberplates up front; 25 mm H-sport in the rear on the softest setting. This has great control over the front camber, turn-in and just turning. And the ride is fine, with good shocks.. The softer you go, the less resistance to the camber change. So I would add the 24 mm JCW bar in betweeen the 25mm bar and the 26mm bar.. Not sure if this helps, but those are your options for front bars.
Ok, my bad on a couple of points...Thanks Way for the clarification.
As for optional swaybars. There is a 25 mm bar from Mini Mania (appears to be solid, but not sure), but that is for the R56. I couldn't find one for the R53 (maybe some else knows of one for the R53). If there is one, then it would be about 17% stiffer than the 24 mm bar. The solid 26 mm bar would be about 37% stiffer than the 24 mm bar.
For the H-Sport front bar, it should have read that it is slightly stiffer than the 23.5mm GP bar. This is actually a hollow 27 mm bar.
Sorry about that. I corrected that post above.
Subw00er (08-13-2018)
Quick Reply: MINI GP2 Track Build for Watkins Glen
