Any tried to fit the mini cargo net?
I was wondering if anyone has tried to use the OEM cargo net in the back of the GP? I need something to stop my stuff from sliding around back there when I'm driving "normal" lol
I have, the one that goes the length of the boot fits.
I had one that also was smaller and attached to a spot just under the rear tray that the GP doesn't have, that one does not fit.
Stuff was flying all over back there so I put the larger one in as soon as I could
Here you go.
Here are the parts from realoem
http://realoem.com/bmw/showparts.do?...85&hg=51&fg=65
The part you want is 51472754568, number 7 in diagram, boot trunk floor net. This does fit, and clips onto mounting points that are there in the GP.
Part number 51472754569, number 8, trunk room lateral net, does not directly fit the GP. The bottom clips do attach to the same mounting points as number 7. However, the GP does not have the attachment point for the top mount. If you want it is easy enough to install a small mounting point here. It would appear that part 9 9, rubber buffer, is the attachment point, which would just then need screwing onto the plastic panel with a self tapping screw.
However, the bottom square net is much more useful than the two side net imho.
Robbo
Aug 7, 2015 05:55 AM
