With the flywheel mod, would any work be required to adjust the computer? In other words, would there be any dependies for correctly carrying this mod. Or is just a simple bolt on job?
Originally Posted by OasisT
... Lightweight flywheel will lose you roughly 15-20lbs I'd guess. Thats a heckuva performance mod too. ...
right ! and........don't forget that lightweight 12 v motorcycle battery! -oops, that was already brought up.
oh, and dip all the body in acid (after you strip everything out of it) to thin out the metal as much as possible! Then you put all your interior that you want - maybe not extra seat and carpeting - and power train back in. (jk,jk) lots o luck!
Suprised noone mentioned it already, but if you chew your tires up to just above the wear bars it oought to cut down on some rotational mass., cut the exausht at the muffler, the tips are just for show.
What is the weight on the GP wheels + tires (separate and combined)?
Anyone have the weights comparing the exhaust system from JCW vs. a Borla or Alta? Any power gain comparisons?
Has anyone removed the armrests from the MINI?
When I removed my JCW exhaust to replace with a Milltek. I weighed them both and the Milltek only came in at 3lbs less.
What about control arms or H-sport comp swaybar? I beleive those weigh a few pounds less than stock and besides the weight loss you will gain a little better in the suspension department.
Control arms are already supposed to be lighter from the factory. Swap the seats sor some fixed back racing ones.
