Stereo/speaker upgrade?
Old Mar 18, 2018 | 06:18 PM
Dasmurph85's Avatar
Dasmurph85
I have a base 2008 Cooper hardtop with the base stereo. It has, as I’m sure anyone that’s ever heard one knows, awful. If I upgrade the speakers would that help at all? Or am I better off trying to find a decent stereo and speaker system upgrade? Not sure how that’d work with everything being built in to the speedometer but hoping to make even a bit of an improvement.
Old Mar 18, 2018 | 07:50 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Bavsound speakers will be a big improvement to those stock speakers. Adding more power with an amp will make you happy. Since you didn't mention it I assume you don't have the HK setup. Try the speakers first.
Old Mar 18, 2018 | 07:58 PM
Dasmurph85's Avatar
Dasmurph85
definitely don’t have the hk setup. Wish so bad i did. Not looking for epic sound but wasn’t hoping speakers would at least improve and I did also read that adding an amp could help also. I’ll see what i can find! Thanks!
Old Mar 27, 2018 | 07:37 AM
Shineywheels's Avatar
Shineywheels
The following percentages aren't accurate just illustrative. Better speakers will improve the sound 20%, an amp will improve the sound 20%. An amp and speakers will improve the sound 150%. The good news is that wiring the amp is easy, there is the X9331 connector behind the left kick panel. Take the speaker output from there and put it thru a high level input amp (or convertor+amp). Don't forget to put in plenty of sound deadening while door cards etc are off.
Old Mar 27, 2018 | 09:06 AM
Shineywheels
I forgot to mention pre-LCI (i.e. your 2008) cars had reduced bass going to the rear speakers so it helps to do a channel swap. Take the rear speaker feed to the front input on the amp and the front speaker feed to the rear input on the amp, this helps as the rear 6x9's can handle the bass better than the front 6.5's.
Old Apr 3, 2018 | 05:57 PM
bratling's Avatar
bratling
Super Moderator
As others here said doing speakers and amp is best. Speakers alone will be an improvement but adding an amp takes it up to a whole ’nother level.
On my 2009 I replaced the front door speakers with a set of Infinity Reference 6500CX components (current version is the 6520CX). I picked up some A-pillar trim with the location for tweeters from the premium sound option, and simply hot glued the Infinty tweeters into place. The crossovers tucked nicely inside the dash.
i installed a JL Audio XD200/2 amp under the passenger seat. I originally bought a less expensive and bulkier amp; it didn’t fit. The XD was just the ticket.
This combination was fantastic. Clear and precise, with plenty of power for bass you can feel.
Between speakers, amp, pure copper wiring, A-pillars, and an X9331 audio harness from Integral Audio, I think I spent around $900. You could spend less and still get quite satisfactory results.
or, for a little more, you could get IA’s incredibly well reviewed SoundStage kit. It’s tuned for each specific model of MINI and is really the best option around, if it’s in the budget.
bigdog100
Aug 18, 2014 12:16 PM
mrravioli3
Oct 30, 2009 04:39 AM
isaacjunk
11
Oct 3, 2009 08:01 PM
bradchatellier
12
Sep 27, 2007 05:54 AM
aVjai
Dec 8, 2002 09:14 AM
