Engine oil : Redline users plz help
Old Sep 10, 2017 | 06:36 PM
hyhenrychan's Avatar
hyhenrychan
I'm going to change engine oil soon, going to switch from Mobil 1 5w30 to Redline 5w30, since the Redline site said that their 5w30 meet the BMW LL-01. I try to order it from Amazon, but there are two different packages, anyone know what different are they?
Old Sep 10, 2017 | 09:13 PM
pianoman011's Avatar
pianoman011
I don't know the differences in the bottles. But if you have an F56 you should be using 0w/20
Old Sep 10, 2017 | 09:19 PM
hyhenrychan
oh...sry i didn't mention my car.. I have a R60 S All4
Old Sep 10, 2017 | 09:25 PM
cadfael_tex's Avatar
cadfael_tex
If you don't get an answer you might try reaching out to Redline. They have been a small company that is good at responding to inquiries like this.
Old Sep 10, 2017 | 09:45 PM
hyhenrychan
What I think it just old and new packages, because I just checked both packages stock number, and the number are same.
Old Sep 10, 2017 | 11:03 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Yes packaging! And just because the photo shows one label doesn't mean you won't get the other one.
Old Sep 11, 2017 | 04:46 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
5w30 is what the dealers used till they ran out, I would never use that 0w20 stuff it's just too light, in a few years you'll start seeing "my car uses oil" threads again
Old Sep 11, 2017 | 07:24 AM
BRGPA's Avatar
BRGPA
The bottom bottle indicates it has extra ZDDP which is an additive useful in flat tappet engines that used to employ lead as an anti-wear agent. I don't know if it helps or hurts modern engines, but you might want to follow others' suggestions and check with Redline.
Old Sep 11, 2017 | 07:50 AM
hyhenrychan
I checked on their website. The one have extra ZDDP is the one they suggest..
Old Sep 11, 2017 | 12:27 PM
hyhenrychan
So I emailed Redline and they confirmed that those two are the same product and just different label.
Old Sep 11, 2017 | 06:34 PM
BRGPA's Avatar
BRGPA
Good, now you can rest easy and order whichever one you want. It's always best to get the info you need direct from the producer. Best of luck...
