Good Mini Scanner that doesn't break the bank
Old Mar 21, 2017 | 05:46 AM
timthechef's Avatar
timthechef
I'm new to minis but I found this scanner and it seems to work really well. It's a Creator C310+. Thought I'd share this review of it for others here. It's pretty cheap and works for many BMW models as well as Minis. I'm still learning how to use it but it seems to do a lot. I got it on Amazon for less than $50. Well, here's the review.
Old Mar 21, 2017 | 09:48 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Both 310+ and 110+ are good deals. Read the codes and resets them.
Old Mar 21, 2017 | 11:04 AM
Dallas_MINI's Avatar
Dallas_MINI
that's the one i bought. i really like the live data stream.
Old Mar 21, 2017 | 11:10 AM
MiniTigger's Avatar
MiniTigger
Where'd you get it Tim?
Old Mar 21, 2017 | 11:28 AM
Dallas_MINI
Amazon. mine shipped from China but it arrived really quickly.
Old Mar 21, 2017 | 01:04 PM
timthechef's Avatar
timthechef
Yup, found mine on Amazon. Got it within a week.
Old Mar 24, 2017 | 10:37 AM
Derek86's Avatar
Derek86
What is the advantage of one of these tools over a generic scanner? I have an non-brand-specific OBDII scanner that I use and it works just fine.
Old Mar 25, 2017 | 04:10 AM
Dallas_MINI
Well for me I wanted one that would give me a live data stream that wouldn't break the bank lol. I was able to see when my low speed fan was cycling and verify the proper temps as it was cycling.
Old Mar 25, 2017 | 04:37 AM
timthechef's Avatar
timthechef
I got mine because I have a Innova scanner for my other cars, a good one that does ODBII and ODBI but it doesn't work with the Mini. It will read the codes but won't clear them. So I got this one just for the Mini. It will do the engine codes and the other codes for the body, AC, and Transmission. It also will monitor in real time telling you what data your car is putting out.
Old Jul 17, 2018 | 07:32 PM
dnsherrill's Avatar
dnsherrill
do any of these Mini specific scanners reset adaptations?
Old Jul 25, 2018 | 11:16 PM
jr_R52's Avatar
jr_R52
Just got an Innova 3130f today because I threw a MIL after installing a 17% pulley. Didn't check all the features on it but it does live data and is bluetooth enabled. It specifically mentions for domestic, asian, and european cars. Will also do OBD i with adapter.
Oh yeah it did read the code (knock sensor) and reseted it no problem.
Old Aug 2, 2018 | 03:35 PM
downshift1's Avatar
downshift1
Make sure you update the software to the newest version as my old Creator now has adaptation reset capabilities in it.
Old Aug 16, 2018 | 05:29 AM
bebevett's Avatar
bebevett
A nice X-mas idea, thanks for the info.
Old Aug 16, 2018 | 06:10 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Just curious here, and I'm asking specifically about the R53 platform...
Is it my understanding the Creator C310 will not, and does not perform the same function as the tool a MINI dealer would use to "dig into" the various hidden options such as modifying one touch window up/down, setting headlamps to go on automatically, various door unlocking patterns, alternate hazard flasher patterns, chimes, etc.?
Or is the C310 more in line with what I have now, which is a WiFi dongle paired to the Dash Command app on my iPhone which allows me to read codes, monitor coolant or intake temperatures, voltage, etc.
Would I need to get into NCS Expert to perform the aforementioned tasks?
Old Aug 16, 2018 | 07:19 AM
downshift1's Avatar
downshift1
Coding is a lot different than a scan tool. For programming / coding you need a bit more hardware as it's writing as well as reading.
The Creator scan tools are just for code reading, live data, and resetting adaptives. I've been told the fancier ones can do steering angle reset and CVT relearn but I have not seen that in person.
Old Aug 20, 2018 | 07:00 AM
Joseph Jones's Avatar
Joseph Jones
Yes, NCS Expert is what you need to code the additional features.
Old Aug 20, 2018 | 07:15 AM
AoxoMoxoA's Avatar
AoxoMoxoA
What I’d really like to find is someone fairly local to me (Boston/Providence area) who is setup and proficient with NCS Expert that I could pay to hook me up and set a few options.
When I’ve called the dealer to inquire about them performing this function (which they can do), the request is met with general befuddlement...
One of of the things I’d like to do is pickup a new toggle panel which has the rear fog light switch and program the upper fog lamp bulbs (already present in my pre-facelift R53 tail lamp assemblies) to function.
Anyone?
Old Aug 20, 2018 | 07:18 AM
Joseph Jones
Anyone?
It is something I could do remotely if you can't find anyone local.
Old Aug 20, 2018 | 07:42 AM
AoxoMoxoA's Avatar
AoxoMoxoA
Sent you a PM.
Old Oct 14, 2018 | 05:19 PM
cosmo727's Avatar
cosmo727
Good Day All
I've got the 2097 code on my 2002 MINI R50 and I can't get rid of it. The general consensus is that I need to erase the code, reset the ECU fuel adaptations, disconnect the battery and short the leads for one minute and leave the battery disconnected for an hour. I tried this procedure with my Foxwell NT510 and could not find an option to clear the adaptations. I ordered the Creator C310+ for the specific reason of clearing the adaptations. The option is there and this what happens:
CBS Reset
Clear adaptation
Communication error!
Please make sure:
1. System equipped?
2. Cable connected ok?
Maybe you can turn the key off, then turn on the key, and try again.
I even tried to clear each individual adaption through the diagnostic menu with no success. There were about 8 or 9 adaptions with a series of numbers and letters followed by "No found!"
Is this option not available on the early MINIs or is that part of the software missing from the Creator C310+ for the early MINIs?
Any help would be greatly appreciated.
I have the latest software update. Version 8.0
