Just a girl who really wants a mini!
Old May 8, 2015 | 10:53 AM
  #26
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Good luck on your Mini search. Be sure to post up pictures when you acquire it!
-Luccia
888.280.7799 | 6am - 5pm PST
Old May 8, 2015 | 07:35 PM
  #27
miniuy's Avatar
miniuy
Originally Posted by Slave to Felines
That may be true for the early ones, but by 2012 they all had sport mode. Mine certainly has it--standard, it was not an option that could be ordered.
Cool !!!
Old May 25, 2015 | 05:31 PM
  #28
MothAudio's Avatar
MothAudio
Bought a one owner 2009 non-s Clubman w/46k miles 15 months ago for $13k from a Mercedes dealer. Clean. Carfax looked straight. Other routine maintainence I had a oil seal and coolant seal leak and barn door lock fail [DIY project]. I would caution you to pay close attention to learn how to read the dip stick and check your oil level often.
Old May 26, 2015 | 10:44 AM
  #29
Charlie Victor's Avatar
Charlie Victor
The sport button is standard on US-market MINIs, but in some other markets it is an option - I think Canada is one of those places, and the OP is from Canada.
Old May 26, 2015 | 11:21 AM
  #30
Osteo's Avatar
Osteo
Yup, an option for us.
D
Old May 26, 2015 | 01:34 PM
  #31
Yea, think its was an option on the sport button for Canada, you can see no sport button on this one.
Old May 30, 2015 | 07:02 PM
  #32
Baoluo's Avatar
Baoluo
Hello all. I'm completely new to mini's. I'm going to start reading older threads but I came to this one first. My question is..."Why do the "S" models get such bad reviews? Is it just certain years? Thanks. Paul
Old May 31, 2015 | 10:04 AM
  #33
AZdsrt's Avatar
AZdsrt
Not all S, mostly the ones with the n14 engine. Which I think was '07 thru '10 or '11. Lots of reported problems with timing chain, valves, etc..
Old May 31, 2015 | 10:23 AM
  #34
Charlie Victor
Short answer: Yes, certain years of the S have had some engine reliability issues.
Long anwer: The first generation S, aka R53 (2002-2006), have a belt-driven supercharger and are considered to be pretty good - lots of mentions here and elsewhere of R53s going well past 100k miles.
Longer answer: The second generation S is divided into cars with the N14 engine (2007-2010), and the later years with the N18 engine (2011-2015). Both of these engines use an exhaust-driven turbocharger. The N14s have had problems with their high pressure fuel pump (HPFP), timing chain and tensioner, turbo oil lines, intake valve deposits, oil consumption, and engine coolant thermostat. The non-S models have also had some issues with the thermostat, but to a lesser degree. MINI has had campaigns to deal with the fuel pump and timing chain/tensioner issues, and possibly the thermostats as well - the parts for all of these are improved now over what those cars left the factory with. The oil consumption issues are possibly partly due to the extremely long service intervals that MINI recommended during this time, as a lot of cars never had their oil levels checked except when the car went in for service - which in some cases was 14,000 miles between recommended oil changes.
The N18 is an improved version of the N14 engine, and has had much fewer issues so far. In particular, the fuel pump and timing issues seem to be largely resolved with these cars, and they eventually started coming with shorter recommended service intervals (9000 miles). Both the N14 and N18 have the same turbo oil line arrangement, so that weakness still exists - there are O-rings that gradually get baked by the heat of the turbo, leading to oil leaks. There are aftermarket fixes for that from Detroit Tuned (and probably others). The N18 is supposed to be less susceptible to the intake valve deposits, but reports are mixed.
Really long answer: Since you're new to the MINI world, let me explain that MINI has muddied the waters some with the model designations and years. The supercharged engine that is in the first generation S (R53) also was used in the Convertible (R52). However, all first-generation Convertibles are R52s, whether they are a Cooper or an S model. The last model year for the R53 was 2006, but the R52 continued on through the 2008 model year. What this means is that a 2007 or 2008 convertible (R52) will have a different engine than the same year model hardtop (R56) - regardless of whether it's an S or not.
The second generation cars are collectively known as the R56 family. In this generation, the model number is the same whether the car is a Cooper, an S, or a JCW. So you can have an R55, R56, R57, R58, or R59 that is a Cooper, an S, or a JCW. The R56 (2nd generation hardtop) went out of production in 2013, to be replaced by the F56 family (third generation). The F-series cars have a whole new engine line. However, while the hardtop R56 went out of production in 2013, the other models based on it (with the N18 engine for the S & JCW variants) have continued on for a while longer. The Clubman (R55) was phased out in 2014; the Coupe (R58) and Roadster (R59) just ended their runs a month ago, and the second-generation convertible (R57) soldiers on for a bit longer, we're told.
To muddy the waters just a bit more, the refreshed, aka LCI for "Life Cycle Impulse" cars (2011 and on) used the N18 in the S models, but kept the N14 engine in the JCWs for another two years. What this means is that a 2011 or 2012 S will have the N18, but a JCW from the same year will still have the N14. The JCWs finally got the N18 for the 2013 model year.
Just to cover all the bases, the Countryman (R60) and Paceman (R61) all use the N18 engine in their S and JCW versions; you won't see a Countryman or Paceman with the N14 engine.
Got all that? Welcome to the MINI world!
Old Sep 13, 2019 | 05:40 PM
  #35
Minidogger's Avatar
Minidogger
Just change the fluid & it will work for a long time. The shift points in sport make it fun to drive.
Kmead
Sep 15, 2019 06:43 AM
Joakester
Apr 18, 2010 05:10 PM
Squadron
Mar 20, 2008 03:30 PM
MINIMCKFLY
Aug 29, 2007 10:15 AM
Gloves
MINIs and Minis for Sale (archive)
12
Jan 11, 2007 04:46 PM
