Compression Loss #3 Cylinder
Anyone had experience with compression loss in a cylinder. My mechanic says #3 is running 120, other three 185.
Rings? Head gasket.
It's a 2008 Mini Base with 98k on it.
Thank you.
Rings? Head gasket.
Thank you.
^ You'll need to perform a cylinder leakdown test to verify where the leak is from.
Being as you have a Cooper, the carbon buildup isn't an issue on your car, so you need to find the source of the compression leak.
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
SneedSpeed
Oct 1, 2015 03:01 AM
