Need Advice: Service Engine Soon Light Weirdness
Old Sep 8, 2014 | 06:55 PM
G8RMNI's Avatar
G8RMNI
Weird thing happened. A few days ago, the Service Engine Soon yellow light went on. I drove the car a couple of times since then, and the light stayed on each time I started the car up.
This evening, ran out to the grocery store, and the light switched off within seconds of the engine turning over. After getting some dessert from the store, I hopped back in the car, turned the car on again and the Service Engine Light Soon light stayed off.
Oh, and the car is a 2006 MCS with 64,xxx miles
What gives? Should I be concerned? Has this happened to anyone else?
Old Sep 8, 2014 | 07:00 PM
ZippyNH's Avatar
ZippyNH
Very typical...
A fault happened.....
Then after it was no longer detected, the light went out after a set number of cycles....
I WOULD suggest you get the code read and write it down....so if it happens again, you can check to see if it is the same code.
Old Sep 8, 2014 | 07:21 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by G8RMNI
...What gives? Should I be concerned? Has this happened to anyone else?
Zippy is right. It could be a bunch of things that caused the initial fault which was transient. Then, after a few miles and cycles the light went off. But it would be good to know the code so you know what you are dealing with as it will probably come back again. <G>
///Rich
Old Sep 11, 2014 | 08:30 PM
G8RMNI's Avatar
G8RMNI
Ok, thanks for the advice. I'll take it to auto zone
and use their free code reader.
09R56
Nov 16, 2022 10:49 AM
W0TM8
Dec 19, 2019 07:50 AM
Aug 14, 2015 01:45 PM
oldkid6
Aug 11, 2015 08:13 PM
