Oil type
Old Mar 29, 2014 | 07:54 AM
cptplt's Avatar
cptplt
Oil type
Sorry if this has been covered but I tried to search for it but found nothing.
Why is the factory oil 5w30 but on the mini owners lounge site suitable alternatives eg Mobil 1 0w40?? Aren't viscosity standards industry standards??
Old Mar 29, 2014 | 09:21 AM
jcauseyfd's Avatar
jcauseyfd
Because the actual viscosity lies along a continuum. Then what MINI recommends for oil is a range as well, which overlaps those ranges.
Old Mar 29, 2014 | 09:53 AM
ZippyNH's Avatar
ZippyNH
It is fine....there is a "range" due to worldwide availability and how engines are machined....some things are not exact....some 5 weights are a bit thicker... Some thinner...even the SAE spec has wiggle room. I would not worry....it is like asking if you have 110 or 120 volt service and if your stove/has 220/240 and some building have 208....but it is refered to as 220....
Very popular oil to use actually....and good stuff!!
Various explanions have been told....but euro mini's list that oil weight as fine....just not common in the us, so I guess it did not make it into our handbook/manual. It is just not worth "non engineer types stressing over....a thousand folks who know nothing more about oil will weight in...
If you are more interested in oil...." Bobstheoilguy.com" website....or very close to it is the place to go...Google it...it is an all oil info site...
Old Mar 29, 2014 | 02:44 PM
Slave to Felines's Avatar
Slave to Felines
The short answer is: All of the weights they list are acceptable, and all will be just fine in your engine.
Old Mar 30, 2014 | 02:30 PM
mbwicz's Avatar
mbwicz
Also, the Mobil1 0w40 is the only commonly available Mobil1 grade that meets the wear standards that BMW has set, that is why they label it as 'european formula'.
No worries using the Mobil1 0w40, also some dealers are pretty reasonable with the factory oil prices, as another option.
Have fun,
Mike
cub4bearindiana
Jun 30, 2016 06:11 AM
HaveATank
Sep 4, 2015 08:04 AM
HaveATank
Aug 24, 2015 10:26 AM
ludedude
Aug 10, 2015 07:16 PM
