Remove E-Brake & Shift Boots?
Old Jun 7, 2013 | 02:33 PM
Ballsy's Avatar
Ballsy
I want to do some custom color stiching on the leather e-brake and shift boots. How so I remove these? I have an automatic transmission if that helps at all. Thanks!
Old Jun 7, 2013 | 03:32 PM
fridayxiii's Avatar
fridayxiii
I found a bit of info from Redline Goods that might help. They make custom shift and e-brake boots for our MINIs. I have a 2006 stick shift and installed both boots a couple of months ago.
The instructions might be slightly different for an auto, and might vary depending on the year of your car. You might check here for some ideas on how to get started.
Redline also might have instructions for automatics, but offhand I'm not sure. HTH some.
Old Jun 7, 2013 | 03:33 PM
twintert's Avatar
twintert
The leathers I purchased came with installation directions. There are clips that hold them down. http://www.redlinegoods.com/MINI07install.php will walk you through it with pictures!
twintert's Avatar
twintert
That was the 2nd Gen instructions if you have a 1st Gen they are also there.
Old Jun 7, 2013 | 03:37 PM
fridayxiii's Avatar
fridayxiii
I don't know about twintert, but for me removing the e-brake mounting frame was harder than the shifter. It definitely took some work.
Old Jun 7, 2013 | 03:43 PM
twintert's Avatar
twintert
I had a different experience. the hardest part for me was getting the leathers to fit evenly over the plastic frames that they attach to.
jziran
Aug 24, 2015 04:50 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
greekzilla
Aug 23, 2015 03:44 PM
