How To Fix a Tail Light Cover?
Old May 8, 2013 | 05:12 AM
Ballsy's Avatar
Ballsy
So my tail light cover (the plastic piece) on my R50 justa cracked in multiple spots. Is there anywhere I could buy just the plastic piece or is there anyway I could repair it? Thanks!
Old May 22, 2013 | 07:47 PM
tenpen's Avatar
tenpen
One of my tail lights got broken while on the dragon this year. I'm interested to see if there is a solution. Mine is $154 pls labor and it has to be the entire assembly. Ug. Until a DIY day I had a tech dab some silicone on it. Looking for other options now.
Old May 22, 2013 | 07:51 PM
Braminator's Avatar
Braminator
You can not just get the cover. You have to replace them. Ebay has lots of them cheap.
Old May 23, 2013 | 04:44 AM
yetti96's Avatar
yetti96
+1, even if you could just get a lens it is a little difficult to separate and make it look clean. Just pony up for a new one, and if they are not going to match because the other side is faded, look at a new set (possibly aftermarket or junkyard takeoffs of OEM)
Old May 23, 2013 | 05:47 AM
All one unit like they said above.
Sometimes they get a little cloudy on the lens with age, if you replace one with a new one, you will be able to tell which is the new one.
The have an enclosed housing. Depends also on what year you have for additional options.
7/2004- Right Taillight
http://www.ecstuning.com/Search/63217166960/ES174660/
7/2004- Left Taillight
http://www.ecstuning.com/Search/63217166959/ES174659/
-7/2004 Right Taillight
http://www.ecstuning.com/Search/63216935784/ES174491/
-7/2004 Left Taillight
http://www.ecstuning.com/Search/63216935783/ES174490/
We also carry many European Spec OEM rear taillights if you are looking for change.
Another option:
7/2004- Tail Light Euro - Driver (Left)
http://www.ecstuning.com/Search/63217166955/
7/2004- Tail Light Euro - Passenger (Right)
http://www.ecstuning.com/Search/63217166956/
-7/2004 Euro Taillight / brake light kit . Top brake light is clear and tailight look like below.
http://www.ecstuning.com/Search/63210150980/ES2580923/
Thanks and that gives you some options.
Sexual Chocolate
Mar 31, 2019 08:02 PM
dyeLucky
Sep 11, 2015 10:41 AM
cm.d
Aug 19, 2015 08:51 AM
messyjesse96
Aug 12, 2015 05:51 AM
