Comfort access: How does the MINI ID the driver?
Old Oct 13, 2012 | 02:46 PM
RonCytron's Avatar
RonCytron
I have looked for some technical explanation of this but did not find anything. My theory based on what I've seen is that the driver ID is obtained only when you use a key in the ignition. If Driver A does that, and then Driver B uses keyless access, the preferences are stuck on Driver A. Does this sound right?
Old Oct 13, 2012 | 02:53 PM
RJKimbell's Avatar
RJKimbell
No, at least not as far as I know, both of my Key Fobs are set up exactly the same. Each Key Fob is programmed to the individual Driver's specifications regardless of whether or not they have been inserted into the Docking Station, the car reads which ever Key Fob is in the closest proximity to the car, typically if you are entering the car and you have your Key Fob in a pocket, hand, etc., then the car should be reading that fob. Hope that helps.
Old Oct 13, 2012 | 03:16 PM
RonCytron's Avatar
RonCytron
OK thanks.
arf88
May 31, 2016 03:07 PM
minicoclub
Aug 25, 2015 09:07 AM
nomar116
Aug 10, 2015 11:24 PM
xpunisherx
Aug 10, 2015 10:50 PM
