Oil question.
Old Jan 11, 2012 | 11:26 AM
miniforceny's Avatar
miniforceny
Oil question.
Can anyone recommend what oil to use on for my Mini. Dealer said to do 15k intervals, but I do not like that. I am planning on 5k oil changes.
Do I have to use BMW oil? Can I use Mobil1 Synthetic? Can I use 10w30 on my new car or 5w30? Thank you for advice.
Old Jan 11, 2012 | 11:31 AM
SpicyMaguro's Avatar
SpicyMaguro
Interestingly, there's a label right next to the dipstick on mine that recommends Castrol. I wonder what kind of joint marketing deal they came up with to do that.
Old Jan 11, 2012 | 01:21 PM
jcauseyfd's Avatar
jcauseyfd
From the Owner's Lounge, if you are not going to use the MINI-branded oil:
The oils listed below meet MINI's Long-life rating and are acceptable for use in MINIs in the US market with gasoline engines.
Long-life rating LL-01 Approved Synthetic Oils for the US Market
  • - Castrol Syntec European Formula SAE 0W-30
  • - Mobil 1 SAE 0W-40
  • - Pennzoil Platinum European Formula Ultra SAE 5W-30
  • - Valvoline SynPower SAE 5W-30
Outside of that list, I'm pretty sure you would want to find something with an ACEA A3/B3 rating. If you are going to use such a short OCI, you probably do not need an oil that meets the LL-01 spec.
Old Jan 11, 2012 | 01:23 PM
proximo's Avatar
proximo
^^^ what he said.
Old Jan 11, 2012 | 02:40 PM
Mindspin311's Avatar
Mindspin311
German Castrol!!! aka the 0W-30.
Old Jan 11, 2012 | 04:28 PM
daflake's Avatar
daflake
Amsoil all the way!
30 is the weight, and the winter rating depends on where you live. 5W is the winter rating that I use up here in DC and that is sufficient.
Any quality synthetic should work though, I have just found that Amsoil seems to be smoother and doesn't burn away as quickly.
What make is your MINI and what generation?
Old Jan 11, 2012 | 04:57 PM
kazlot's Avatar
kazlot
Oil question
Can I use 10w30 on my new car?
No
Yes
No
See the list of approved oils that 'jcauseyfd' posted.
Hope this helps...
Old Jan 11, 2012 | 06:00 PM
miniforceny
Thank you all. I got 2012 Mini Cooper ( not S).
Old Jan 12, 2012 | 10:44 AM
miniforceny
Now I am confused. Opened the hood last night, There us a sticker in the engine, USE SYNTHETIC 5W30. Read car manual and there are a list of few oils to use.
Old Jan 12, 2012 | 11:00 AM
scf's Avatar
scf
Living in NH here. Planning on 0w30 with snow tires, and 5w30 without snow tires. That make sense to the seasoned veterans here?
Old Jan 12, 2012 | 11:26 AM
Clubman S Turbo's Avatar
Clubman S Turbo
Mobil1 synthetic 5W30
Old Jan 12, 2012 | 12:04 PM
kazlot's Avatar
kazlot
Oil question
Don't be confused by the sticker.
If it's like the one my 2006, it is recommending the 5w30 Mini branded oil.
There should even be a part number printed on the sticker as well.
All you need to do is use one of the recommended oils, listed in your manual or on the Mini website, and change it at least once a year.
That would occur on the anniversary of the delivery date even if the mileage is less than what the count down computer calls for.
Your free maintenance most likely covers what they call a "low mileage oil service" which is an oil change and quick visual inspection.
Hope this helps...
Old Jan 12, 2012 | 12:25 PM
Braminator's Avatar
Braminator
Mobil1 synthetic 5W30 with no issues.
Old Jan 12, 2012 | 12:37 PM
Clubman S Turbo
These engines seem to be somewhat more suseptable to oil quality related issues than some others, so I go 7K max with Mobil1 5W30, ignore the on-board oil computer, and idle down the engine for at least 30 seconds if you just came in off the freeway or whatever and weren't just puttering around the block for the last 2 or 3 minutes. That gives the turbo time to spool down to minimum rotational speed and extend its bearings life.
The issue with the timing tensioners may be partially oil-related as well, as they are hydraulic assemblies and rely on proper engine oil pressure to tension reliably. Swap to the new revised part number assembly as soon as possible to avoid complete tensioner system failure. I am going to do a catch can next, then maybe intercooler this spring or early summer, then a tune.
Old Jan 12, 2012 | 03:53 PM
Yoda Mini's Avatar
Yoda Mini
0 weight! Why such a light oil?
Old Jan 12, 2012 | 04:02 PM
scf's Avatar
scf
Getting some racket when I start Trillian in the morning.
Old Jan 12, 2012 | 04:31 PM
drsimmons's Avatar
drsimmons
Been using Castrol 5/30W full syn. but going to switch to Mobil 1 0/40w Europeon formula full syn. Easy to find and Mini also recommends. Also, seems lots of folks on here use it.
Oh.....15K intervals, no way. I do mine at 7K.
Old Jan 13, 2012 | 07:43 AM
AAONMS's Avatar
AAONMS
Oil is such a personal thing.
Many folks seem to get really worked up over this for some reason, but it is a personal choice.
I’m no longer a fan of Mobil1.
Previously been a customer on my cars, Jeep, and race car over 20 years.
Blackstone used oil analysis showed an upward trending wear problem in my Jeep.
After several analyses, they recommended changing to a different brand of oil.
Did so and the wear numbers are back in tolerance.
Am now using Valvoline or NAPA (made by Valvoline) synthetic in my Jeep and German Castrol 0W30 in the MINI.
More info that most would ever care to know about oil: www.bobistheoilguy.com
If you have a spare hour, here is some good reading: www.bobistheoilguy.com/motor-oil-101
Old Jan 14, 2012 | 06:16 AM
Teibito's Avatar
Teibito
Using oil
I'm using Castrol Syntec 5W30 in my '09 JCW. I change the oil and filter about every 7500 miles, which is half the recommended interval in the manual.
I have 35k miles on the car and I thing I'm using more oil than I should. I'm putting in about 3/4 to a full quart every third fillup, which is about a 1,000 miles.
Anyone else notice this much oil usage? My dearler tells me that turbo cars burn more oil than non-turbos.
Old Jan 14, 2012 | 06:24 AM
drsimmons's Avatar
drsimmons
Dealerships all say the turbos can use up to a quart every 1K-2K miles. Personnally, I havent' noticed that with my 07 S. I have added maybe a quarter of quart within 3K but that's it. I don't drive mine hard so that may explain my low oil usage however, I did add a half quart at one time after I had ran it hard on a club gathering. So, I'm thinking if you drive it harder you may use a little more oil. Also, I suspect that each car is different and usage is going to vary. Ensure that you don't have an oil leak somewhere as well. I also change my oil every 7K miles rather than the recommended 15K (that's crazy IMO). I've been using 5/30w Castrol Edge but I think I'm going to switch to 0/40 Mobil 1 Europeon formula next change.
Old Jan 17, 2012 | 07:43 PM
Clubman S Turbo
Teibito, I ran to Ohio a few weeks ago, from Baltimore, 417 miles through the I70 and the PA Turnpike, 75 to 80 most of the way and climbing to 2700 ft elevations in the Tuscarora Mtns. Used just under 1/2 quart from time leaving to time arrival, Mobil1 5W30 so 1 qt per thou sounds about right if spirited driving. I alkso change at around 7.5K, no way Im doin 15K. The previous owner lunched the turbo at 37K, Im bettin the 15K intervals were why.
Old Jan 18, 2012 | 05:46 AM
drsimmons's Avatar
drsimmons
^^^Totally agree with ya.
Old Jan 20, 2012 | 07:16 AM
miniforceny
Thank you all for the input. As I read thru the posts, I have another question. Just keep in mind, this is my first MIN.
Why would a car use up oil? Is this common with all MINI's? I had toyota's and Nissan's for past 20 years. Drove over 100,000 miles each car and never needed to add oil between 5k miles oil changes. thx.
Old Jan 20, 2012 | 07:28 AM
drsimmons's Avatar
drsimmons
Personally, I'm not 100% in agreement with Mini's eating oil. My 07 doesn't. I think the S models may due to the turbo but than again mine is an S. I don't drive it hard but one time that I did, I did eat through about a quarter of a quart.
Also, with the plastic valve cover which is prone to warp you may get an oil leak from there. Again, mine with 63,800 miles on it now still has the original valve cover. They did replace the gasket when they did my timing chain repair.
I have gotten a little paronoid about oil reading all these threads so I check my oil about twice a week just to be safe.
Old Jan 20, 2012 | 08:12 AM
Clubman S Turbo
MiniForceNY, the vacuum present in the intake system pulls oil from the turbo bearing seals and sucks it into the engine. At high rev high vacuum conditions, this is exacerbated, but is completely normal. You also have the differential pressure with the oil pump pressurized oil on one side and the vacuum chamber conditions on the other side. No bearing seal is ever perfect, and for the life protection of the turbo, a little leakage is actually preferable, it keeps the seal coated both sides with nice synthetic slickness. Personally, I'll suck a few bucks of Mobil1 through my engine over blowing a $1K+ turbo any day of the week. My next project is going to be a catch-can for the EGR system.
