List of mod/replacement that need alignment
Old Dec 5, 2011 | 08:07 PM
vodka's Avatar
vodka
Hi all,
Just trying to come out with a list of mod or replacement which need alignment after done. Below is based on my assumption (I'm not expert on this). Please feel free to add or correction.
1. Aftermarket suspension/coilovers - Yes (need alignment)
2. Lowering spring - Yes
3. Outer ball joint #10 Link - ??
4. Wheel bearing - No
5. Lower arm bush #8 Link - No
6. Innser ball joint #12 Link - ??
7. Drive shalf - ?
8. Steering rack - Yes
9. Steering column - ?
10. Steer spindle #1 Link - ?
11. Tie Rod - Yes
Thank you
*Thanks, updated the list...
Old Dec 5, 2011 | 08:26 PM
Slave to Felines's Avatar
Slave to Felines
Lowering springs, yes--if you need an alignment with coilovers, you need an alignment with lowering springs. If nothing else, to make sure the toe angle stays in spec.
Steering rack, yes. You have to remove the tie rods to replace that.
Old Dec 6, 2011 | 10:10 AM
Slave to Felines
Mr. Bentley says that any time you loosen the bolts on just about any of the front suspension components that you need an alignment. So that would be "yes" on the ball joints (inner and outer) and the bushing on the A-arm.
I think they might be a little overzealous? Not sure, though--I haven't worked on any MINIs.
Keet
SCCA Solo and ProSolo
Sep 19, 2015 09:45 PM
Shane Wendel
Sep 18, 2015 06:18 PM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
Sep 10, 2015 11:55 AM
OutMotoring
Sep 8, 2015 06:27 AM
