Remaping ECU
Old Oct 26, 2011 | 02:05 PM
lostmini's Avatar
lostmini
Remaping ECU
Its probably been ask a hundred times, but im very new to this forum & this is my first post so please take it easy on me
Ive just done a transmission swap on my 02 Mini that had a very poorly made Automatic trans , dealer wanted millions to fix.
I just dropped in a Standard/manual trans from a 06 mini, was a easy to do swap i just had problems finding a pedal/bracket , car runs great drives well. ive put more then 100+ mile on it and ran with a charm. until yesterday it died!!!!!!!!!
I did not change any wires or computer from the auto trans, I posted some help info on another website, there reply was to remap my computer for a manual trans.
is this true & does anyone know how this is done?? any DIY out there??software?
im really want to get her back on the road asap..
Old Oct 27, 2011 | 06:05 AM
klricks's Avatar
klricks
It's amazing you even got the engine started without changing any electrical.
Get a code reader and see if there are any AT related codes. The system may have shut down thinking there is a serious problem with the AT?
Everything on this car is programmed from engine to fog lights.
I don't know if a different ECU would be needed or just reprogramming the existing module(s)? You might look for on-line parts or at a dealer and compare part numbers.
Old Oct 27, 2011 | 12:27 PM
lostmini's Avatar
lostmini
The mini started right up after i jumped 2 wire near pedals...
The car does not run now, has to be the ECU telling the car the Automatic has shut down, I really need something to remap the computer.. I have a code tester but it is just that and nothing more.
Old Oct 29, 2011 | 04:14 PM
redpoopercooper's Avatar
redpoopercooper
you may want to check this forum posting, it does have all the info for remapping your ECU.
https://www.northamericanmotoring.co...trag-swap.html
did you go with the 6spd. getrag??
Ive seen many do that swap also, takes about a day or two to complete.. What did you do with your transmission? sell the shell to trans shops prob. get a few $100 for it. If not take a gal. of gas and burn that rubbish, worst transmission ever made.
bahman
Feb 14, 2016 10:29 AM
mni928
Nov 9, 2015 07:38 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
genik
Cooper (non S)
Sep 25, 2015 02:46 PM
Sep 25, 2015 12:32 PM
