Oil changes
Old Sep 19, 2011 | 02:10 PM
rtruesdale's Avatar
rtruesdale
Oil changes
I just bought a 2011 mini s and understand i don't need to have it serviced for one year. I'm a bit uneasy with this as I typically like to do this at least every 5 thousand miles.
Any thoughs on this?
Also, I have close to 4k on it now and it "looks" as though the oil may be a bit low. is this normal for the break in period?
Old Sep 19, 2011 | 02:53 PM
bluefox280's Avatar
bluefox280
You should be uneasy; a lot of engine component failures have been attributed to low / excessive use oil.
Changing it out 5K miles is a very very smart move for longterm ownership.
I currently change my 2009 every 4K without question.
How low?
Consumption is attributed to break in, where the piston rings seat into the engine block and oil vapor through the PCV system.
BMW / Mini "allowable" consumption rate is approximately 1 quart for every 1000 miles... excessive to some, but tolerable to the manufacturer.
- Erik
Old Sep 19, 2011 | 03:38 PM
rtruesdale's Avatar
rtruesdale
I want to say its about half-way on the stick. Not too bad but... As you said feel its mostly due to break-in and settleing.
I sure wish they can make these dip sticks easier to read!!
Thanks for being my sanity check
Old Sep 19, 2011 | 04:40 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Change and check your oil frequently in these French Engines.......seems to be the ounce of prevention for them.
Especially important to always keep it topped off.
CardinalsRule
Jun 11, 2016 04:34 PM
molala
Oct 2, 2015 01:53 PM
Sep 4, 2015 09:10 AM
Sep 3, 2015 03:01 PM
Sep 2, 2015 09:05 AM
