Fuel In Stored Mini
Old May 18, 2008 | 02:48 PM
jedorme's Avatar
jedorme
Fuel In Stored Mini
We will be storing our '07 MC in our air conditioned garage for 3-4 months this summer in California. The local Mini dealer advised to fill the fuel tank & add some stabilizer. But here in CA they add ethanol to our fuel (about 6% to 10% I think) and an engineer friend tells me that over time gas will separate out from the ethanol which will turn into water in the bottom of the tank, and this will create problems when next running the engine. Does anyone out there know anything about this possibility or have any good advice?
Old May 18, 2008 | 02:54 PM
that7guy's Avatar
that7guy
I stored my Miata with less then 1/8 tank for 3 months over the winter and after I filled it up it started right up and ran fine. Thats with 8% Ethanol.
Old May 18, 2008 | 03:33 PM
Alpha Motoring's Avatar
Alpha Motoring
My MINI used to be a garage queen, now it's driven but not much, but when I used to store it for about a month or so, I'd top off the tank. The problem that I noticed though is that, the car seemed to lack a bit of performance with the older gas, other than that, it ran perfectly!
Old May 18, 2008 | 05:53 PM
bad venge's Avatar
bad venge
The fuel Stabilizer seems to help with "water" and seperation issues ...
We store motorcycles for 4 months yearly and they fire up and run fine ...
Old May 18, 2008 | 07:15 PM
minimarks's Avatar
minimarks
Use stabilizer and it should be fine, be sure to put it in and run the engine for a little while so that the treated fuel is in the entire fuel system..
Old May 18, 2008 | 07:28 PM
chpsk8's Avatar
chpsk8
I store my cars for 4-5 months a year with full tanks and a little SaBil in the gas. we have 10% ethanol blended gas here. I never have problem when starting up.
Old May 18, 2008 | 09:28 PM
ED955S's Avatar
ED955S
I also store mine during Mid-Oct to Mid March. I have used Stabil and Gunk Fuel Stab with full tank of 93 Octane gas with good success for the past 3 years. I also start and run the engine for 20 minutes twice a month. If your battery is getting old, use a trickle charge like Battery Tender.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini'mon
Aug 26, 2015 01:02 PM
kpl
Aug 11, 2015 04:52 AM
bc219
Aug 10, 2015 11:22 AM
