Tires Feathering
Old Dec 16, 2010 | 11:01 AM
klipper's Avatar
klipper
Tires Feathering
I have a 2009 JCW Clubman and my winter tires as well as my summers are feathering on the inside half of the tires. It seems like a camber issue.
Is this a normal problem to have with the JCW's? Is the camber set up this way for performance?
Any help would be appreciated.
Thanks.
Old Dec 16, 2010 | 01:53 PM
MINIdave's Avatar
MINIdave
Is it stock, or have you done some stuff to it, like lowered it?
If it's stock, I'd say you need an alignment....
If you've lowered it, could be a bunch of things....but either way first I'd put it on the alignment machine and see what it says. Toe out will wear the inside edges too. Also, have you rotated the tires? I do mine about every 5K - really helps with the wear....
Old Dec 16, 2010 | 05:00 PM
MINI33342's Avatar
MINI33342
The feathering has more to do with toe than camber and can be effected by a bad shock or even bushings.
Old Dec 17, 2010 | 10:24 AM
klipper's Avatar
klipper
My summer tires are not bad, they are on the stock 17" rims, but my winter tires are bad. They are on 17" aftermarket rims with a higher offset..... Could the offset be contributing to feathering on the inside of the tires?
schwac2
Jun 14, 2016 04:06 PM
dpike
Sep 12, 2015 08:19 AM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
Ntety
Sep 2, 2015 08:39 PM
