F55/F56 Less boost with Forge pipes
Old Sep 29, 2019 | 12:38 AM
El-Grunto's Avatar
El-Grunto
Anyone install Forge's hard intake and intercooler pipes and test boost PSI before and after? I seem to be having some trouble with mine. Using the stock pipes on my RPM Stage 2 tuned F56 S I was hitting 21/22 pretty regularly with the highest being 23.4. After install I'm hitting about 16-18. Highest I've seen is 18.2. All of the connections seem good and I can hear the air moving much more than before but I don't think it's the sound of a boost leak. But with a drop in PSI that big I can only think that that's what it is. Might just have to have a shop do a smoke test to make sure there isn't a leak.
Old Sep 29, 2019 | 02:52 AM
Triwingar's Avatar
Triwingar
So far I am running the Forge intercooler with FTP charge pipes, I don't have any boost losses after the installation. Could potentially be a leak but I have heard that the FTP pipes vs the Forge pipes are different
Old Sep 30, 2019 | 10:09 AM
hadjiikong's Avatar
hadjiikong
Did you take the four rubber o-rings out of the old inter-cooler pipes and put them into the new ones?
Old Sep 30, 2019 | 10:33 AM
El-Grunto's Avatar
El-Grunto
Yup, all are installed. And of those 4 rubber seals MINI only sells 3 separately. The 4th can only be gotten with the $300 OEM pipe. Guess how I know.
Old Oct 3, 2019 | 07:04 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
Guess how @hadjiikong and I know you need those 4 stupid rings .........
Old Oct 3, 2019 | 09:07 AM
El-Grunto's Avatar
El-Grunto
Again, the OEM rings are on the pipes. We took them off the OEM pipes and put them on the Forge pipes. One pipe came undone while driving and the seal was lost. That seal has been replaced after buying the $300 OEM pipe just to get the seal. All the seals are there.
Old Oct 4, 2019 | 07:35 AM
Mini_Vinnie
Moderator
You missed my sarcasm. We didn't know about the rings and installed the pipes, then the CEL fun came on. The Forge instructions didnt reference them
Old Oct 5, 2019 | 12:09 PM
El-Grunto's Avatar
El-Grunto
Yeah, it went way over my head. At least yours had instructions. We had to use your blog for the install since ours didn't come with any and we couldn't find them on Forge's site. The driver's side pipe was already on when we realized we needed to reuse the OEM seals.
Old Oct 8, 2019 | 08:21 AM
Mini_Vinnie
Moderator
Ha! Well ..... at least I helped a bit
El-Grunto
Aug 2, 2023 09:03 AM
Daniel Carulli
Sep 30, 2019 08:12 PM
cstrumol
18
Mar 3, 2017 07:28 AM
Dek766
Nov 10, 2012 12:41 PM
Bahamabart
Oct 8, 2006 02:26 PM
