F55/F56 New F55 s handling issue, poor cornering
Old Mar 24, 2020 | 03:19 PM
  #26
Imperial's Avatar
Imperial
Originally Posted by robby71
I have the stock JCW 18"s with the Pirelli runflats, all stock suspension (normal not DDC) and don't have the floaty feel.
I've changed the pressures to 36 / 34
In my 2016 MCS the sticker says 39 PSI for all 4 tires. When tire pressure naturally goes down with time and car shows less than 36, then of course the ride is a bit softer but it introduces more road noise and I feel road imperfections more. So I keep tires filled to 39 PSI. What I did notice is that 2020 MCS which is exact same car with same wheel size, had 38 front and 35 rear on the sticker. I don't really get this...why is that?
What was your recommended pressure on your vehicle and why did you change it?
Old Mar 24, 2020 | 03:30 PM
  #27
robby71's Avatar
robby71
Maybe the 2020 model is a slightly different weight?
I can't remember the pressures on the sticker but i reduced mine as i thought they were too high, ok for fuel economy but a bit harsher on our potholed roads
Old Mar 24, 2020 | 04:41 PM
  #28
Imperial's Avatar
Imperial
Could be a bit different weight but the car had the same specs as mine just without dynamic dampers. Of course the tires were Pirelli Cinturato P7 RTF
Oh, I see, I though you did it for something specific to get better handling or to correct an issue with cornering. So you basically did it to ease the road harshness. Our roads are not that bad I guess, less potholes, just regular imperfections and different types/patches of asphalt.
Downside on my tires is that front left is leaking a bit of air and it has been like that over a year since I bough the car used. Doesn't seem to be a hole as it may take weeks of gradual air escape and front right does it too, but is bit less. Rear tires stay filled properly for longer time.
Old Mar 25, 2020 | 05:19 AM
  #29
robby71's Avatar
robby71
My tyres are also the Pirelli runflats
You should have got your leak sorted if it's been happening for a year, maybe the sidewall has broken down slightly due to low pressure? over in UK we can have runflats repaired if they have a puncture (some garage say you can't to try and sell you a new tyre), could also be the valve leaking?
Old Mar 25, 2020 | 11:22 AM
  #30
Imperial's Avatar
Imperial
I did an oil change in the MINI two weeks ago and told them to check valve stem if it is not tight/loose. They supposedly looked but couldn't find anything. No cracks that I can see and tire is no more than 4 years old. If it is not factory defect, then I can let all air out and then pump the air back to make tire re-seat on the rim. I recently received valve tool, so will check to see if valve core is leaking air, if it does, then I will tighten it or have MINI replace it.
Old Mar 25, 2020 | 12:09 PM
  #31
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
That seems odd, did you check the owners manual? Maybe they put the wrong sticker on the car. I've only seen front/back MINI tire pressures being the same on the ALL/4 set ups like our old CM. Got a picture of the label?
Old Mar 25, 2020 | 12:18 PM
  #32
Imperial's Avatar
Imperial
So on my 2016 MINI it is 39 PSI on all 4 tires. That 2020 MCS loaner had 38/F and 35/R. It was on the door sticker. I only took a picture of the car before giving it back
Old Apr 8, 2020 | 05:03 AM
  #33
Infamus's Avatar
Infamus
my 2020 F56 (BTW neebie here) says 36F 32R. When I had the car delivered I took it for a ride and the first thing that I noticed was the huge roll effect it had and the steering felt twitchy... checked air pressure and it was 40/40 reduced it to what is noted and now its a lot better still has some sway but may be since I'm coming off an M2 I need to adjust...
Old Apr 8, 2020 | 08:38 PM
  #34
N0B0DY's Avatar
N0B0DY
The 2019 owner's manual lists a bunch of different tire pressure settings based on the wheel and tire sizes that was installed in your car. The Sticker on the door is good for the tire wheel combination that the car left the factory with. They also list different recommendations if you drive over 100 MPH .
Old Apr 8, 2020 | 08:53 PM
  #35
Imperial's Avatar
Imperial
Yes, the manual does list tire pressure according to the model and below or above 100 MPH. So the sticker on my car shows PSI that is under 100 MPH. If I would drive mostly over 100, then I think PSI goes up to 45 or a bit less. I usually try to do 39 or 40 in all tires and this provides with a good overall road feel.
Old Apr 8, 2020 | 08:56 PM
  #36
Imperial's Avatar
Imperial
Oh you recently bought the car? If that is the case, Congrats! The steering wheel does feel too sensitive at times and requires micro corrections from the driver.
Old Apr 9, 2020 | 04:52 AM
  #37
Infamus's Avatar
Infamus
oh yea for sure very sensitive but its a blast so far. Can't wait for the break in to end.
Old Apr 9, 2020 | 12:34 PM
  #38
Imperial's Avatar
Imperial
I remember when I bought a new car (another brand) over 10 years ago and was driving around town to make break in period end faster
Old Apr 9, 2020 | 01:05 PM
  #39
Infamus's Avatar
Infamus
thats me... even with the local lock down I'm finding excuses to take a drive... what better social distancing than in my car alone with the window up driving around.
NamBot3000
Oct 17, 2019 03:39 PM
cmdycrzr
Wheels/Tires/Brakes
30
Jun 25, 2019 12:00 PM
Dwink
Tires, Wheels, & Brakes
Jan 20, 2017 02:30 PM
MiniMeR50
Oct 14, 2014 06:45 AM
shark715
Jul 16, 2012 06:58 AM
