F55/F56 Has anyone tried putting a brighter bulb in the front side turn signals?
Old Dec 5, 2016 | 01:15 PM
umberto's Avatar
umberto
Crazy idea .......the headlights, just the standard halogens so no cornering lights, in my 2016 4 door really have very little side illumination, so when you turn at an intersection on a dark country road you are turning into darkness. I was thinking of seeing if a brighter bulb could be used in the front side turn signals to at least give a little light as you turn ....has anyone tried this? Not sure if a bright bulb will fit or if a higher wattage bulb would burn out some electrical component or cause some code light to be tripped ........any thoughts on this crazy idea?
Old Dec 8, 2016 | 03:03 PM
umberto's Avatar
umberto
hmmm ..i guess no one has tried this, but any thoughts as to if using a brighter bulb will affect any of the electronics?
I went to my local AutoZone and the side turn signal bulb in our manual is a W5W which is listed at 50 lumens......autozone says that it cross lists as your basic 194 bulb, and sylvania makes the 194A LED , clear, that i think is listed at 90 lumens ...so would be brighter though certainly not like a cornering light but would be better than how it is now, and being an LED i would think it would be drawing less current than the stock W5W ( which also may make the electronics notice something is different a send some code that a bulb is burn out) ......
thoughts anyone???
thanks
Old Dec 8, 2016 | 03:50 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
A = amber not clear I believe. Also make sure it is canbus capable.
Old Dec 8, 2016 | 06:10 PM
umberto's Avatar
umberto
ahh ....you're right ...package said 194A ..the guy said this was amber but he was out of stock in clear but it would be a little brighter ...what is can bus??? is that the LED with a resister to draw a load to make the electronics think it is an incandescent bulb/ if so, will it designate it as such?
Old Dec 9, 2016 | 12:38 PM
siriuszero's Avatar
siriuszero
In my experience, LED bulbs have a more intense light, but it does not travel as far as an incandescent will...
