F55/F56 FS: ALTA (AMP-SUS-100) Adjustable Control Arm, Rear, Set of 2
Old Aug 9, 2016 | 08:19 PM
Matt Wooley's Avatar
Matt Wooley
I bought these never installed them or even opened the box till i was selling them. Just looking to get rid of these.
$250 free shipping for the lower 48 states.
Here is all the info from Alta's site and if fitment will work for your mini.
DIRECT REPLACEMENT
ALTA Rear Control Arms directly replace your rear lateral links. The solid design of the ALTA control arms improve traction and handling. As well as giving you far greater control over camber and toe settings on your MINI. Once installed, ALTA control arms are adjustable for fine tuning of camber and toe without having to remove and install the linkage. Simply loosen the adjustment lock nuts and twist the center section to the exact setting you desire. These are easily installed when adding other suspension products like springs, coilovers or swayers.
CONSTRUCTION
The ALTA Rear Control Arms are CNC machined from 6061 aluminum rod and then heavily texture powder coated for corrosion resistance as well as adding some color to your otherwise boring undercarriage. They feature Teflon-lined spherical rod ends for a solid connection, greater articulation and prevent dynamic alignment changes that occur with the rubber bushings found in the OEM control arms.
BEARINGS
The ALTA Performance Control arms use an aircraft quality, spherical bearing type of rod end. This solid type connection still allows for smooth and precise movement of the control arm through a far larger range of articulation. Our rod ends use injected Nylon around the center of the ball to keep the ball joint quiet as the part ages.
QUAD ARMS
Two sets of arms can be purchased to replace both sets of upper and lower control arms. Further increasing rear end adjustment, removing even more deflection from the OEM rubber bushings and reducing even more weight from your MINI. Please note on models with Xenon style headlamps the installer will have to modify the mounting for the leveling sensor. Contact your ALTA dealer or our Tech Dept for additional details.
HARDWARE
The ALTA Rear Control Arms use high quality hardware including corrosion resistant spacers and high quality Grade 8 adjustment nuts.
COMPATIBILITY
2002-2006 Cooper Yes
2002-2006 Cooper S Yes
2004-2013 Cooper Convertible Yes
2004-2013 Cooper S Convertible Yes
2008-2013 Cooper Clubman Yes
2008-2013 Cooper S Clubman Yes
2012-2013 Cooper Coupe Yes
2012-2013 Cooper S Coupe Yes
2012-2013 Cooper Roadster Yes
2012-2013 Cooper S Roadster Yes
2009-2013 JCW Yes
2010-2013 JCW Convertible Yes
2009-2013 JCW Clubman Yes
2012-2013 JCW Coupe Yes
2012-2013 JCW Roadster Yes
Countryman No
Paceman No
Old Aug 9, 2016 | 08:27 PM
vetsvette's Avatar
vetsvette
Moderator
This belongs in the 1st and 2nd Generation Classifieds. Not applicable to 3rd Gen.
Old Aug 9, 2016 | 08:31 PM
Matt Wooley
its gotta be me being a new user but i can't seem to locate the classified thread you speak of.
Old Aug 9, 2016 | 09:10 PM
vetsvette's Avatar
vetsvette
Moderator
Here ya go.
https://www.northamericanmotoring.co...f11-4-5-6-7-8/
Old Aug 9, 2016 | 09:11 PM
Matt Wooley
life saver!
Old Aug 9, 2016 | 09:14 PM
vetsvette's Avatar
vetsvette
Moderator
No problem Matt. They don't make it easy to find. Good luck.
Old Aug 9, 2016 | 09:17 PM
Matt Wooley
done and done, many thanks.
DOCWESTON
Mar 29, 2016 08:06 AM
quickcoop
Mar 19, 2016 12:41 PM
Suspension Products
Mar 17, 2016 04:17 PM
PelicanParts.com
Mar 14, 2016 10:23 AM
PinkMiso
Mar 11, 2016 10:32 AM
