F55/F56 Aftermarket wheels
Aftermarket wheels
Aside from tirerack, what are some other places to look for wheels for the F56? It's been a while since I've looked at wheels and I don't know what the big vendors are anymore. If it's against forum policy to post here, can you pm me the websites?
Thanks for this, I'm having a hard time finding much available. I assume the new bolt pattern and high offsets don't help. If I can find a decent gold or bronze colored wheel, it will change my color choice. I don't think I like any of the stock wheels enough to powdercoat them.
It would be nice if VMR's fit, but they all seem too wide.
You can try:
www.ecstuning.com
www.elementwheels.com
www.fifteen52.us
3sdm.co.uk
www.imagewheels.co.uk
www.rotiform.com
Replicas:
www.esmwheels.com
That might work. The thinnest adapter you can get is 15mm as far as I know, so some of the BMW wheels that have conservative offsets (like et 44 on an 8" wide wheel) might fit. Judging from R99's pictures I suspect the sweet spot will be 18x8 et 30-35 for the fronts. Probably much more room in the back.
My absolute favorites were Type 162s and I almost bought a set right before we figured out that the F56 isn't 5x120.
They're 18x8 et 34. I'm still thinking about having my hubs dual drilled to BMW fitment.
We have Genuine MINI wheels here for the F56. Adding more each day.
http://www.ecstuning.com/Mini-2014-Cooper-F56-S-3_Door-B48A20A/Wheels/OEM_Alloys/
http://www.ecstuning.com/Search/SiteSearch/36116858705KT/
These seem to be poplur.
Center caps, They Pre F56 ones are different so you cannot swap them.
http://www.ecstuning.com/Mini-2014-Cooper-F56-S-3_Door-B48A20A/Wheels/Center_Caps/
Outmotoring has center caps that they say fits on F56 and all other black center caps. They are colored in red, green, orange and yellow. There are oem they say. Is this correct?
I've just faced the same challenge, but was able to find what I needed at Tire Rack in the form of the Sparco Asiento Garo.
These are 16x7, 5x112, 48 ET, and the correct center cap diameter. A hair over 16 lbs too.
They are legal in G Street, which is the destiny of my F56.
However they are not gold...
Cheers,
Charlie
Cheers,
Charlie
mini Coop - They are for the F56 wheels, we have them under the center caps section of the F56. Just click on the second link with the center-caps and picture of the JCW version. Not for pre F56 MINIs. Come in green, red, orange, and yellow.. As a set of four, easy to swap.
randomquickness - H&R has spring out right now for the F56, that's one of the newest items out for suspension. We should see more aftermarket here soon. Buts that's what we have right now.
http://www.ecstuning.com/Search/SiteSearch/28813-1/
ltjpunk7
Sep 6, 2015 07:32 AM
Aug 21, 2015 11:25 AM
