F55/F56 Nitrogen and Future of Spare Tire
But do you really think they are filling the tires with it? Maybe topping off and balancing the pressures but shipped from the manufacturer they should be just right when they leave.
I'm not sure what the dealer does when they get the car. Normally the tires are very over inflated while being shipped. The dealership should set the correct pressure. From what I understand the machine they use can 'flush out' the air and swap it with nitrogen.. at least a very high percentage of nitrogen.
I never use (higher concentration) nitrogen because it's a pain in the butt and not worth it to me.
Checking tire pressure regularly should be part of any car owners regular routine. I have two driers on my air tool setup at home so the rusting TPMS argument doesn't hold much water (heh heh) for me.
At $5....might be tempted...
But at $70 PURE DEALER PROFIT AND MARKUP.....
RUN....then check your tires for air with the tpms... Add as needed...likely every 3 months or so.
I hope they topped of your "blinker fluid"..... Seems many drivers are out!!
Mine is thru Advantage Mini of Clear Lake also. Car should be coming off the ship in Brunswick today if I got the ship correct, so hope to have it in 1-2 weeks. No adder on my spec sheet for Nitrogen. Will see what they say about N2 in the tires when I pick it up.
