F55/F56 Stud Conversion for F56 Cooper S - Questions
Hi folks,
I think I am going to run a stud conversion on my car to aid better fitment of my Speedline wheels which need ball seat bolts or nuts - there is simply not a singe manufacture of M14x1.25 ball seat bolts!!!!
So - enter the need for a stud conversion!
I have seen the Way Motor Works studs here: http://www.waymotorworks.com/m14-to-...ountryman.html
They seem pretty decent, and should enable me to find some M12 x 1.5 ball seat tuner nuts.
It says 52mm will be protruding from the hub - does that mean only open nuts can be used for these studs OR would a set of closed nuts be able to be used too?
On determing whether open nuts or closed-end nuts will work, you'll need to measure the mounting pad of your wheels and determine how much of that 52mm the wheels will take up.
52mm sounds like a lot of stud to me.
Has anybody put on these studs on the stock wheels? I don't like working with the bolts even with a wheel pin or 2 and a lot of maintenance tasks requires the wheels off.
I was thinking of these: http://new.minimania.com/part/G2NMW4...-Kit-M14-X-125
I have a 2015 MCS with the stock 16 inch loop wheels.
Cheers
Aug 12, 2015 01:24 PM
Aug 10, 2015 02:03 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
