F55/F56 Washing your new car
Old May 11, 2014 | 02:11 PM
  #26
GregoryK's Avatar
GregoryK
That groove I mentioned in the opening post. The one on either side of the wiper blades is now full of dirt. It is a really terrible design detail.
Anyone have any idea of how to clean it. Guess you could run a business along it. I am think of cutting mine off and making something myself. it's clearly an afterthought.
Old May 12, 2014 | 07:09 AM
  #27
randomquickness's Avatar
randomquickness
^post a pic of that spot
Old May 12, 2014 | 10:46 AM
  #28
MotorMayhem's Avatar
MotorMayhem
I washed my car again this weekend and didn't find the area I believe your describing to be loaded up with dirt. There wasn't much there and it was essentially cleaned out from when I gave my car it's pre-soak. Now admittedly over the last week my car did not get super dirty nor was I driving in any area with loads of loose dirt.
On a side note I am also extremely pleased how much cleaner the F56 exhaust pipes stay. On my R56 I had to regularly wipe these down every other day to keep em clean.
Old May 12, 2014 | 11:25 AM
  #29
shraz's Avatar
shraz
Is there an easy way / trick to remove the antenna? My MA told me it should be removed at the car wash.
Old May 12, 2014 | 11:28 AM
  #30
MotorMayhem
yup, you just unscrew it; it should hold in place snugly but should twist off when you need it to.
Old May 12, 2014 | 11:49 AM
  #31
VicSkimmr's Avatar
VicSkimmr
Just the tip though, the base stays.
Old May 12, 2014 | 11:53 AM
  #32
Mrdi's Avatar
Mrdi
Originally Posted by russmini
Leaf blower works well at getting water out of mesh areas and grill.
Dry the car w/a leaf blower.
Saves wear and tear on the paint
Wax lasts longer
Use a natural hog;s hair brush to wash
Soft, gentle, effective.
http://www.ebay.com/itm/Montana-Original-12-inch-Boars-Hair-Wash-Brush-car-auto-Pamper-Your-Paint-/310503374976?hash=item484b718080&item=310503374976&pt=Motors_Automotive_Tools&vxp=mtr
ALSO, more options
http://www.autogeek.net/boar-s-hair.html
Old May 12, 2014 | 12:38 PM
  #33
Llanrhaeadr_Cymru's Avatar
Llanrhaeadr_Cymru
Originally Posted by randomquickness
I do a little detailing on the side. I'm happy to help out as well. This is what my wifes '10 looks like after 4.5 years and almost 53k miles
Mercy, that looks nice! I try to keep my motor and compartment clean, but that is truly magnificent! My approach is get keep things clean bit by bit, and not let the dirt get too far ahead.
Old May 12, 2014 | 01:18 PM
  #34
randomquickness
Thanks, it's actually very easy to maintain that. It's only when you neglect it for a long time that it can get tougher.
Old May 12, 2014 | 03:24 PM
  #35
kg4fxg's Avatar
kg4fxg
Washing Car
As stated already the detailers 101 Forum is excellent.
For me I started with Griots. See www.Griots.com I hear great things about Black WOW for the black parts around say the fenders.
Griots has a book that is helpful for those of us who are OCD. I got a nice wash bucket on wheels with a screen. With the right tools, micro-fiber cloths washing is fun easy and simple.
What I learned is that much of what I use can't be had at Walmart. A little investment lasts a long time. Glad I took the time to learn.
Old May 12, 2014 | 03:30 PM
  #36
GregoryK's Avatar
GregoryK
Here's the area I am referring to...it's a very tight groove
Attached Thumbnails Washing your new car-dsc02207.jpg   Washing your new car-dsc02208.jpg
Old May 12, 2014 | 03:34 PM
  #37
GregoryK's Avatar
GregoryK
Also what do you make of this. The body side of the door locks look like it has been sprayed with acid. these marks don't come off. The 3rd image is the drivers side that is not as bad. they generally look terrible though. Any thoughts?
I dropped by the Mini Dealership and the service guy said they all looked like that.....is that true??
Attached Thumbnails Washing your new car-dsc02205.jpg   Washing your new car-dsc02206.jpg   Washing your new car-dsc02209.jpg
Old May 12, 2014 | 03:44 PM
  #38
shraz's Avatar
shraz
So pretty much a screw is holding it?
Old May 12, 2014 | 05:12 PM
  #39
Mrdi's Avatar
Mrdi
A hippie runs that galvanizing booth
A tie-dye look.
The galvanizing is developing a patina.
Pop em off and spray them w/ flat black Rust-o-leum
That's what I did on my MB Sprinter
Old May 12, 2014 | 05:19 PM
  #40
Mrdi's Avatar
Mrdi
Greg,
Can you finely spray that area clean with the hose when you begin to wash the Mini
Old May 12, 2014 | 05:32 PM
  #41
Fly'n Brick's Avatar
Fly'n Brick
The cabrio has a similar space in the rubber molding where the top of the boot hatch meets the frame. It collects a lot of dirt. I squirt some water in there and then run a rag pushed down in there with a screwdriver. Comes out pretty clean. There's a couple of more effective methods I can think of, one being to quit obsessing over it, so it gets cleaned when it becomes obnoxiously evident.
Old May 12, 2014 | 05:41 PM
  #42
GregoryK's Avatar
GregoryK
Fly'n Brick. Yep probably right! But it is a stupid detail none the less. I build and design for a living...In good design every detail is thought through.
Old May 12, 2014 | 06:24 PM
  #43
MotorMayhem
Indeed, here is a pic of the standard antenna removed where you can see the screw tip.
Old May 12, 2014 | 06:27 PM
  #44
MotorMayhem
Yah that is the area I thought you meant. I have an adjustable hose nozzle that has a setting to spray the water out at an downward angle, this works well to run along that edge and get stuff out of there.
Old May 12, 2014 | 08:07 PM
  #45
randomquickness
looks to me like you could spray it with your hose and a micro fiber wash mitt would fit in there if that's what you use. Also, if leaves or debris got stuck in there, I'd think raising the bonnet might free it up.
Old May 12, 2014 | 08:58 PM
  #46
Fly'n Brick
[QUOTE=GregoryK;3930597] But it is a stupid detail none the less. QUOTE]
Obnoxiously evident!
Old May 24, 2014 | 08:49 AM
  #47
JS24's Avatar
JS24
That looks horrible and no they do not all looks like that. I'd have them replace those.
Old May 25, 2014 | 05:31 PM
  #48
champ198's Avatar
champ198
I've washed a Countryman, an 07 Cooper, and a Coupe. This F56S takes the longest of all of them to wash the front end. All the new grooves and lines and hard corners make it difficult to clean. Getting beside the brake duct covers with a sponge is doable, but you gotta work hard at it. Bugs just seem to be attracted to areas your sponge can't get to. GregoryK is correct, the honeycomb faux grills just seem to hold water.
To BMW, I challenge your engineers to actually wash and clean the cars they design.
Old May 25, 2014 | 05:55 PM
  #49
GregoryK's Avatar
GregoryK
I had a bird poop on my back hatch and it really etched the paint. I had to sand it with 2000 grit then polish out to remove. Now I am paranoid that clear cost seems soft.
Have the car a wax and the thunder grey is just like black. Every scratch and mark shows up....looks good when clean..But I doubt it will age well. Can't believe that I have 4 chips on my hood already!
Going for the Xpel skin.
Old May 25, 2014 | 08:28 PM
  #50
russmini's Avatar
russmini
I've noticed water drip marks below the front part of the doors, just like my 2008 and 2011 Mini's. Where were the engineers? Also had bird poop etching in my 2014 just like my 2008. This etching doesn't happen on my wife's Lexus.
