F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
F56 Clunk and Fluid Leak on Passenger Side
Old Apr 19, 2025 | 08:16 PM
2JZ-Sienna's Avatar
2JZ-Sienna
Hi everyone! I recently picked up an F56 2015 Cooper S and I’m sooo happy to be back in a Mini. When I got home from buying it, I hit a speed bump a bit fast and heard a loud clunk from the front passenger side. :/ I was thinking suspension so I turned the wheel full right to see if there were any visual clues and found this fluid all over the subframe and inlet piping. It’s kinda yellow like synthetic oil but very thin so I thought it was the motor mount but it looks to be in decent shape to me. Has anyone had a similar leak in the same location and maybe know exactly how they fixed it? 😃
bonus points if anyone can ID this loose bolt i found sitting on the cowl too
Old Apr 21, 2025 | 08:47 AM
https://www.northamericanmotoring.co...-oil-leak.html
Possible oil pan? Can you drop the fabric belly pan and take a look?
Its not part of the cowl kit? https://www.ecstuning.com/Search/Sit...h/51717301013/
Its a security torx head, must have been from a repair? Its a short one, i checked all the bolts and dont see one that's common? I would start looking around the engine bay.
Old Jul 19, 2025 | 06:27 PM
2JZ-Sienna's Avatar
2JZ-Sienna
Update!
It’s a security torx head, must have been from a repair? It’s a short one, i checked all the bolts and dont see one that's common? I would start looking around the engine bay.
Alright so I pulled the trigger on the engine mounts and swapped them out. The clunk didn’t go away but these definitely needed to be replaced.
I replaced the lower control arms and the clunk went away. There’s some bad vibrations still so shock top mounts are next. I guess I should’ve done it all at once 🤷🏻
rk15000
109
Mar 26, 2026 10:41 AM
ekh2000
Jun 12, 2024 09:09 AM
EFGmini
Oct 29, 2022 08:49 AM
RegieB
May 23, 2016 12:16 AM
tommy_zito
20
May 8, 2007 10:13 PM
