HPFP Failure
HPFP Failure
Posted this on the wrong section - sorry.
Hello, I have a 2015 F55 base, which went limp and stalled out within seconds while I was driving pretty conservatively in a parking lot. After that, it kept stalling and I had to tow it back home.
It would also make helicopter/rattling sounds when I unlocked it or tried to start it. At home, my Carly said it had 11B018 (Fuel Pump, Fuel Pump Controller: Speed Missing), 110001 Cylinder injection shutdown: Kastchultz because of pressure too low in fuel system.
My regular cheap OBD loaded P142e, which I believe is HPFP failure that ravaged older BMW 335s.
The car mysteriously started again the next day, but I'm too scared to drive it. I have been using my other car, but I prefer the Mini for its handling. Is it a HPFP failure? Should I replace the HPFP? Anyone had this issue? I know this was an issue in older R models, but not here.
Thank you again.
Thank you again.
DomesticMuscle
Factory JCW Talk (2009+)
Nov 22, 2013 08:46 AM
Guthrie
Jun 18, 2012 04:24 PM
