F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
Broken T-Map Securing Clip
Old Jul 18, 2018 | 11:45 AM
Dpark0514's Avatar
Dpark0514
Last night I was removing the T-Map sensor plug and I broke the little grey securing clip from the T-Map sensor plug. Does anyone know how I might be able to replace this connector plug?
Old Jul 18, 2018 | 12:01 PM
vetsvette's Avatar
vetsvette
Moderator
The grey clip is not a big deal. I lost mine not long after the initial installation, but it never caused a problem.
Old Jul 18, 2018 | 12:11 PM
Dpark0514's Avatar
Dpark0514
I noticed that the back tab had broken off but the part that is inserted in the slot is still in there. Should I just remove the whole clip? I wasn't able to remove the plug after I installed it due to that piece still stuck in the slot.
Old Jul 18, 2018 | 12:28 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Should be able to manipulate the leftover plastic piece with a mini pick type tool. If you don't have one, Harbor Freight sells a set of them for a few dollars. Good thing to have in toolbox.
Old Jul 18, 2018 | 01:13 PM
TVPostSound's Avatar
TVPostSound
Lost mine too.
Lift the tab from the right inside side of connector, and pull connector away.
Tybo88
Sep 7, 2017 07:56 PM
Jassim96496
Feb 25, 2015 11:54 AM
godzilla
Mar 11, 2009 06:42 AM
dguig
Mar 25, 2008 04:49 PM
